It is currently Thu Jan 24, 2019 9:46 am
PostPosted: Sun Oct 29, 2017 5:53 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
I have a small antifreeze leak coming from under the thermostat housing.
I am going to install a thermostat gasket that I ordered.
I believe there is not one on there now.
Did Pontiac not use a gasket under that housing?
Thank you.
PostPosted: Sun Oct 29, 2017 8:49 pm
on my 2000, there is an o-ring in a groove surrounding the thermostat - check to see if yours is in good shape.
https://www.google.ca/search?q=2000+pon ... Ti2ESWRCFM:
you can see both above......wait 2 seconds for the actual pic to load: its from the 'other' site.
PostPosted: Sun Oct 29, 2017 8:56 pm
There should have been one there (I assume), but if it is leaking from there, then there is not one present. I dealt with the same issue about 3 weeks ago. Make sure you clean the thermostat and the housing surrounding it. It's an easy fix.
'02 Pontiac Bonneville SE 105k miles, N/A, SSEi exhaust system.
PostPosted: Mon Oct 30, 2017 3:15 pm
There isn't a paper gasket between the housing and the intake manifold. There is an o-ring around the thermostat. Make sure both the face of the intake and the face of the housing are clean and flat, and clean them with a scotch-brite if they're not. You shouldn't need a gasket unless something has gotten warped or something.
PostPosted: Sat Jan 27, 2018 12:41 pm
Year and Trim: 96 Bonneville SSEi
I just changed the thermostat and gasket on my 96. It was a paper gasket that ripped in half when I removed the neck. Half the gasket stayed on the block and the other half stayed on the neck. I scraped it all off, installed the new t-stat with the o-ring properly seated and then used some red gasket maker on the neck and reinstalled the whole thing just to be sure. It has not leaked.
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
PostPosted: Sun Jan 28, 2018 12:24 pm
I added some RTV, even after cleaning the mating surfaces there was a tiny trickle of a leak.
There are no new unread posts for this topic. 1992 L27 thermostat housing gasket
Merrillspontiac
Fri Jan 21, 2011 11:37 pm
There are no new unread posts for this topic. Thermostat?
Dopey85
12
1188
Tue Jun 08, 2010 11:27 am
Bugsi View the latest post
There are no new unread posts for this topic. Need a 180* Thermostat?
LeSabre in Buffalo
Fri Oct 01, 2010 11:29 pm
There are no new unread posts for this topic. bad thermostat?
96 SSEi
Wed Jan 17, 2018 10:02 pm
96 SSEi View the latest post
There are no new unread posts for this topic. 180* Thermostat Observations
LeSabre in Buffalo
Thu Aug 07, 2008 2:44 pm
