It is currently Wed Jan 17, 2018 8:10 pm
 Post subject: Seeking Opinions...
PostPosted: Thu Sep 14, 2017 12:44 am
For the 2000+ interior...
*** IF *** you were to think about refinishing the center console trim parts (shifter plate & cup holder), what colour/finish would you select? Would you also do the instrument cluster/radio trim and traction control panel or leave them alone.
Carbon Fibre Appearance Interior Trim, Highly Modified Main Body, Instrument Panel, Door, Door Panel & Headliner Wiring
Harnesses, Custom Fuse Box & Tire and Loading Information Decals, Additional Acoustic Insulation
 Post subject: Re: Seeking Opinions...
PostPosted: Thu Sep 14, 2017 9:33 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I personally like a very light tan with a darker brown accent on leather. The areas that would get dirty from use like the armrests and steering wheel, would have to be the dark brown.
Kinda like this:
Basically, anything, as long as it's not '90's grey, is cool with me. I am a fan of interiors matching the exterior, but only if it's done right.
I don't know how much boost it takes to blow the tires off. But I know how much I'm going to use!
Runs:
'93 Pontiac Bonneville SSEi - Twincharged, manual, racecar! Build thread
'97 Chevy Camaro - 3800, T5, T-tops, my DD
'89 Buick LeSabre Limited - winter DD
'97 Buick LeSabre - L67 project
Doesn't run:
PostPosted: Thu Sep 14, 2017 4:31 pm
I used to toy with the idea of wrapping that whole area, radio/climate trim and all, with the same brushed black metal that I've done my door handle and vent bezels with. However, they don't make the wrap wide enough, and hydrodipping is pricy.
If it were me, it would have to be some kind of metal, maybe aluminum or similar. Or a dark gray/black wood. I would do all of it in order for it to look more complete.
"Penelope" - 166k Miles
PostPosted: Thu Sep 14, 2017 9:01 pm
I like Matt's thoughts on areas prone to becoming soiled, and in the photo, it looks nice. I've got the Pewter interior so in some respects it's more difficult. I think there's a wider range of options and things I could do with a tan interior because other colours can be added and look good. You can't add a lot of different colours to the pewter interior without looking gaudy :(
I also see what you're saying Carl. What you propose is a little tricky as well because with the brushed metal door handles in the GXP, everything else would need to be the same or it wouldn't look right. Hydrographic printing is a little more costly, but I'll spend the money to get the best end result. One thing I didn't mention here is that I've already had 11 pieces finished/refinished with hydrographic printing. Whatever I do will need to fit with that as well.
Here's the thread to my rear heated seats. Toward the end you'll see what I did...
detailing-appearance/topic10782.html
I'm really reluctant to finish these additional pieces in the same pattern because I just think it will be too much carbon fibre. I need something else that will be a fit and offer some contrast.
PostPosted: Thu Sep 14, 2017 9:51 pm
Believe me I've read all of your threads... For fun... Haha. That new CF print looks so much better than the GXP stuff.
How about the same color and style as the door handles themselves? Might be tricky, and it might also be too much contrast. But you never know.
PostPosted: Thu Sep 14, 2017 10:02 pm
GM's problem was trying to make a carbon fibre appearance trim that was interchangeable between the tan and gray interiors. That resulted in the marginal looking stuff they ended up with for production. I absolutely agree that the new pattern and colour is 1000x better than the original.
Getting the very same brushed look with the same sheen as the metal door handles will be a big challenge. I am also worried that it would be too much just given the surface area of the center console parts.
My brain keeps going back to refinishing in the same colour that GM used and calling it good. To complete my current project, it absolutely needs to be done. I thought this would be the opportunity to change it up a little but... There just seems to be so little that can be done with this interior short of a complete remodel. :sad:
PostPosted: Fri Sep 15, 2017 9:49 am
'05 STS-4
'97 LeSabre
I take it you're not going to consider swapping to the tan interior then?
For some reason I thought your car had tan.
Runs:
Doesn't run:
PostPosted: Fri Sep 15, 2017 10:53 am
That would be a cool color combo, but seems like a lot of work. Might be best to just repaint with GM factory color.
PostPosted: Sat Sep 16, 2017 4:30 pm
No, it would be a huge expense. Not that difficult to do, just a lot of parts! I really like the gray in that it doesn't show dirt or some types of imperfections nearly as easily. I don't believe GM ever offered the tan interior with Graystone Metallic/Spiral Gray Metallic.
There are no new unread posts for this topic. Saying hello and seeking advice...
BonWolsfeld
Sun Dec 09, 2012 3:20 pm
Bugsi View the latest post
There are no new unread posts for this topic. Opinions on This Car?
Blown93SSEi
11
946
Sun Jul 20, 2008 12:52 pm
radomirthegreat View the latest post
There are no new unread posts for this topic. Your opinions on this car
94SilverSSEi
Mon Sep 29, 2008 1:58 pm
Boreas View the latest post
There are no new unread posts for this topic. Opinions please?
nishnobguad
Sat Feb 08, 2014 7:25 pm
There are no new unread posts for this topic. Opinions please!
Datbonneville1
Fri Jan 31, 2014 8:35 pm
Datbonneville1 View the latest post
