It is currently Tue Apr 16, 2024 12:01 am
PostPosted: Thu Apr 13, 2017 9:36 pm
Year and Trim: 2004 SE
Sorry, I'm a bit of a noob. Tried to find out elsewhere so I wouldn't have to make a post about it and bother people, but I honestly have no clue how to tell was trim level my '04 Bonnie is.
Help appreciated! :)
PostPosted: Fri Apr 14, 2017 9:48 am
If it has a single exhaust, it's an SE. If it has dual exhaust, it's an SLE or GXP. If there is one rectangular-ish exhaust tip on each side, it's an SLE. If there are two round exhaust tips on each side, it's a GXP.
WHITE WHINE - 1992 SSE Supercharged 236.26 ci (.040 Over) 15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers and 10" Subs, 1300 watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, Ceramic Coated Ported Exhaust Manifolds, Fan Override
PostPosted: Fri Apr 14, 2017 9:52 am
Thanks!
PostPosted: Fri Apr 14, 2017 10:13 am
SE:
SLE
GXP
You can also run the VIN on most any free online VIN decoder, and it will usually tell you.
PostPosted: Fri Apr 14, 2017 12:21 pm
Year and Trim: 2013 Regal GS
The SE has one exhaust pipe, the SLE has dual exhaust with oval-ish tips, the SSEi has dual exhaust with trapezoidal tips, and the GXP has the twin dual exhaust, with 4 total pipes coming out the rear. The SE, and SLE has the regular 3.8L V6, the SSEi has the supercharged 3.8L V6, and the GXP has a 4.6L V8.
'13 Buick Regal GS 102k miles, 270 hp, 295 lb/ft, ZZP intake.
PostPosted: Sun Apr 16, 2017 3:34 am
If you look at the your VIN, the fourth and fifth characters tell you what body the vehicle is and the trim level.
HX = SE (H-Body, SE Trim)
HY = SLE (H Body, SLE Trim)
HZ = SSEi or GXP (H Body, SSEi or GXP Trim)
Here is a link to a GM VIN Decoder card for your model year...
https://service.gm.com/dealerworld/vinc ... card02.pdf
There are no new unread posts for this topic. cant figure out paint code on my 1995 bonneville ssei
RossThaBoss
Thu Sep 27, 2012 6:43 pm
RossThaBoss View the latest post
There are no new unread posts for this topic. 98' to 95' Bonneville trim change .. ?
Murphy
Fri Oct 14, 2016 10:06 am
95naSTA View the latest post
There are no new unread posts for this topic. Thinking about changing SSEi trim to regular trim
lou
12
1680
Mon Jan 30, 2012 7:08 pm
There are no new unread posts for this topic. What was your favorite Bonneville, year and trim level?
1oldman
19
1782
Tue Jun 24, 2014 2:41 pm
There are no new unread posts for this topic. How do I remove the window trim (upper) on my 61 Bonneville?
Bonnimon
Tue Mar 21, 2017 3:12 pm
