It is currently Sat Feb 16, 2019 3:48 pm
PostPosted: Wed Apr 05, 2017 4:59 pm
Year and Trim: 1999 Bonneville SSE
Car will run all day on idle in the drive way, when warm as soon as you put it in gear it dies. We have replaced the battery, fuel pump (was told it loses fuel pressure when it dies), crank shaft sensor, many relays. I am really at a loss here. Even mechanic said they don't know and then said to pick up my car they would not work on it anymore.
Anyone have any ideas on what this could be? Oh yeah when it died, I was driving and when it was about to die I noticed that my window motors were very slow going up and down.
PostPosted: Thu Apr 06, 2017 10:20 am
I would check out the battery connections and the ground buss locations under the carpet at the bottoms of the a-pillars. They are rectangular bulges in the harnesses.
PostPosted: Fri Apr 07, 2017 12:39 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
If you put your foot an the throttle and hold 1000rpm does it die when you put it in gear? (make sure your foot is on the brake...)
Runs:
Doesn't run:
PostPosted: Sat Apr 08, 2017 6:15 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
The fact that your ignition switch had some issues makes me suspect that may be the problem.
These threads have info that may help (including a wiring diagram) , as the VATS may also be the cause
1992/topic33924.html
post40085.html?hilit=testing ignition switch#p40085
post454572.html?hilit=vats starter#p454572
There are no new unread posts for this topic. (New here) 1999 Bonneville SE stopped and will not crank
Skishuss
Tue Apr 04, 2017 10:55 am
Skishuss View the latest post
There are no new unread posts for this topic. 2005 Bonneville gxp won't start electric problem help!!!
Bluebonnie05
Thu Jun 30, 2016 12:25 am
There are no new unread posts for this topic. Weird G8 Issue last night... (new crankshaft...)
3323
Wed Oct 16, 2013 10:37 am
There are no new unread posts for this topic. electrical issues
sseienthusiast
Mon May 07, 2012 11:01 pm
sseienthusiast View the latest post
There are no new unread posts for this topic. Need some advice on a few Electrical issues.
SubjectSatyr
Mon Sep 03, 2018 8:09 pm
ddalder View the latest post
