It is currently Sun Feb 17, 2019 10:32 am
PostPosted: Mon Oct 10, 2016 1:12 pm
Year and Trim: 2000 bonneville
I have read most of the common fixes on all doors except drivers, not been able to track this down yet...Have found water leaks but no bad wires found yet... I did find I have 12V on both wires going to the lower door panel lights.... What would cause this ? Pulled a bulb and tested it and all bulbs are good... I only have like 1.4 volts on one wire on the driver side switch panel, nothing lights on the panel... Can the drivers side module cause this ? I keep looking and can't seem to find where the switch panel gets all its voltage from also.. I can check the voltage just not sure where to start... I wondered if the 2 wires are shorted from its source causing 12V on both wires to the lower door panel bulbs ? No gnd ' just 12v on both wires.. Didn't check the rear bulbs ' but both front bulbs have 12v on both wires....
No blown fuses' but did notice RAP Relay/INT LP Relay/ Cigar Relay staying warm after ign turned off.. Something still ran the battery almost down overnight' with these 3 relays pulled out... thanks
There are no new unread posts for this topic. 2000 bonneville se
wdudetocool
Wed Apr 25, 2012 7:01 pm
wdudetocool View the latest post
hi3150
Tue May 08, 2012 10:18 pm
There are no new unread posts for this topic. 2000 Bonneville.
rustyroger
Sun Jun 24, 2012 5:50 am
rustyroger View the latest post
There are no new unread posts for this topic. 2000 Bonneville shuts itself down
bolds88ville
Tue Feb 03, 2015 9:26 am
There are no new unread posts for this topic. Looking to buy a 2000 bonneville sle white
glenn304bonne97
Fri Jan 20, 2012 12:00 pm
Ken_W View the latest post
Users browsing this forum: No registered users and 14 guests
