It is currently Fri Jul 10, 2020 9:43 am
 Post subject: 20 wheels
PostPosted: Sun Aug 30, 2015 12:14 pm
Year and Trim: 2002 Bonneville SE STOLEN
2001-05 Bonneville GXPI
Ok a guy is willing to trade me his Boss 328 wheels 20 inch rims. The wheels were supposedly from a 2012 infiniti g37. Bolt pattern 5x114.3 with a 50 high offset. Will these fit on the bonnie without issues?
 Post subject: Re: 20 wheels
PostPosted: Sun Aug 30, 2015 12:48 pm
Strictly from a hube bore standpoint: The Infiniti's hub bore is smaller. Find out if they were using hubcentric rings, and if so what the hub bore in the wheels is. If the hub bore is 70.3mm or larger you may be able to make them work. As long as the wheels are hubcentric, the 114.3x5 bolt pattern works w/out issue.
Offset is a function off rim width. Without knowing the width, the offset means nothing
07 Infiniti G35s 6MT
PostPosted: Mon Aug 31, 2015 12:11 am
I'm guessing these are the numbers
www.summitracing.com/parts/aew-3286-2815/overview
PostPosted: Mon Aug 31, 2015 1:05 am
The bolt pattern and offset don't match what you said.. and these wheels seem to come in a lot of different measurements.
PostPosted: Mon Aug 31, 2015 2:03 am
Yea I know. I looked on there website hence the link but I'm pretty sure he wouldn't know the technical portion of his rims. So I did my own research so what do you think
PostPosted: Mon Aug 31, 2015 2:38 am
There's no hub bore info.
PostPosted: Thu Sep 10, 2015 9:12 am
Year and Trim: 2004 SLE
50mm offset sounds too deep...possible rubbing issues with strut tower or tie rod
2004 Bonneville SLE "Bonnie the Ghosthawk" or the 4dr Firebird...Gone but not forgotten
The Blog, http://www.tobthebat.wordpress.com
Luna LeMans on Smashwords
https://www.smashwords.com/books/view/870754
Luna LeMans in Amazon paperback
https://www.amazon.com/dp/1983273589
PostPosted: Thu Sep 10, 2015 10:07 am
Yeah but 50mm at what width? That might make all the difference.
There are no new unread posts for this topic. gto wheels
dadofone2011
Wed Mar 04, 2015 12:26 pm
There are no new unread posts for this topic. whose wheels are these????
spoiledred94
Thu Sep 10, 2009 1:44 am
There are no new unread posts for this topic. Will these wheels fit?
*B2*
18
2122
Thu Aug 28, 2008 10:57 pm
*B2* View the latest post
There are no new unread posts for this topic. New wheels.. That don't fit
Bumzag
15
1231
Tue Sep 22, 2015 8:33 am
96 SSEi View the latest post
There are no new unread posts for this topic. Help! What size are my wheels??
Ludichris
15
1855
Sun Dec 12, 2010 1:47 pm
