It is currently Sat Feb 16, 2019 10:16 am
 Post subject: 2005 GXP help!
PostPosted: Sun Feb 09, 2014 10:42 am
I am looking to get an 05 GXP and aocal dealer has one! My question is what specific areas should I be paying close attention to when I got look at it? Also what should I be listening for on the test drive? I also hear that the low coolant light coming on is sometimes an issue. Any thoughts on this?
Thanks!
 Post subject: Re: 2005 GXP help!
PostPosted: Sun Feb 09, 2014 3:58 pm
What's the mileage?
These motors are a gasket nightmare, and it doesn't help that they are crammed into such a small space.
I'll let one of the Northstar Buffs chime in with a more detailed answer.
PostPosted: Sun Feb 09, 2014 10:35 pm
Search.
- Cam cover gaskets and the fact the bolts like to loosen from heat cycling, causing leaks
- Cooling system leaks
- Standard GM oil cooler line leaks
- Occasional head warpage and head gasket failures requiring head work and restudding
- 4T80E Pressure Control Solenoid sticks occasionally on higher mileage cars causing maximum line pressure, hard shifting
- Infamously retarded fog light setup gaurantees that they go out frequently
- Lots of electronic brain farts
Also, GM by 2005 had moved on to CAN. This being a 2005 it is most likely a CAN Hig speed LAN network for it's OBD system. 2004 is a regular OBDII setup.
Then add in the normal Bonneville maladies. The issue with this car is that it is a size 10 engine in a size 5 dress. So unless you're doing the work yourself, which adds time, then the person you pay is gonna charge you that time. There is a whole GXP section to paruse.
PostPosted: Sun Feb 09, 2014 11:25 pm
2004 Bonneville GXP
check the coolant for contamination and check the oil for coolant contamination. make sure you don't smell a coolant odor under the hood, there are several places that coolant leaks develop. Make sure all the gauges work properly, look under the common problems in the 00-05 Bonneville section for the rest of the common issues like sunroof leaks, intermediate steering shaft clunks, leaks in the trunk (check the spare tire well), front wheel vibration at highway speeds, etc. Look under the engine for oil leaks, they are not uncommon, valve cover gaskets, oil pan, rear main seal
bobgto65
PostPosted: Mon Feb 17, 2014 4:36 pm
The mileage is a tick under 60,000 Idk if these cars are reliable though they seem to not.be by these posts!!
PostPosted: Mon Feb 17, 2014 5:47 pm
Figure this. With 60k on it, you have about 40k of happy, uneventful driving. When they (N*'s), hit 100k, they start being "needy". That doesn't mean that they're unreliable or that you're going to be left to walk home, just saying that it may start nickel and diming you, and being a size 10 engine in a size 5 dress, those nickels and dimes become $50 and $100 bills instead.
Of course you will get the obligatory "I've got 626k on my N* without ANY issues..."
That's awesome! However stats are stats and it seems consistent that at about 100k they just become "needy".
PostPosted: Mon Feb 17, 2014 8:03 pm
Year and Trim: 2004 SLE Premier Edition
2005 GXP
So, did you buy it? I see in your avatar that you have a 2005 GXP listed as your car. Any pictures?
Tell us what your thoughts are, if you can.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
There are no new unread posts for this topic. Looking at buying a 2005 GXP vs 2005 SLE vs 2003 SSEi
7tcatvert
33
4267
Sun Feb 19, 2012 2:07 am
There are no new unread posts for this topic. 2005 GXP
DCMain
25
1163
Sun Sep 07, 2014 7:28 pm
techweenie View the latest post
There are no new unread posts for this topic. 2005 SLE I might buy
Benvw99
20
1590
Tue Feb 09, 2016 3:15 am
unclebubbaSE View the latest post
There are no new unread posts for this topic. Bonneville GXP 2005
Spitzkindl
12
1138
Mon Feb 11, 2013 4:09 pm
There are no new unread posts for this topic. New 2005 SLE w/ 40,000 miles...
wwade2
Mon Oct 15, 2012 11:44 am
