It is currently Mon May 20, 2019 7:40 pm
PostPosted: Sun Feb 24, 2013 3:46 am
Year and Trim: 2002 SSEi White/Tan 236k.
88, 89, 91 SSE
89, 90 SE
A friend of mine has an 04 GP GXP with factory fob. I'm wondering if a module can be added from the GP to the Bonnie (02 SSEi) for this feature. I have considered android app controlled RS/KE/A systems, but I would really prefer to keep the 2 person seat memory function.
Found my first TINY paint chips on the hood and two on a door, so I bought an arctic white chip paint, tried it under the hood next to the fender so I could check the color match, was too bright. Didn't see a color code on the door patch. Do I look this up from the VIN? Any thoughts on using zink based cold galv spray on areas under the car or in the gas filler pocket? Should I just find a body shop and have the chips fixed, and then have the hood herpies removed? Thoughts on the clear coating for extra protection on the nose of the hood?
Oh yeah, I would like to find the trunk net and replacement tiedowns, missing those and the inflator/accessory kit, and ONE rear floor mat.
Is it normal for the radio to skip over programmed stations when changing stations from the steering wheel?
When it was -10, one of the steering wheel control lights came on, but shut off when it got warmer. Contact ring problems?
Another weird observation: Pulling up a hill at highway speed causes fluctuation, thanks to this forum, I understand the most likely reason why. However, when I'm climbing the same hill on cruise control, there is no surging. Could it be too weak a throttle spring? sounds unlikely.
Loving this car so far....but already thinking about power upgrades....
Image2002 SSEi Owatona, MN
PostPosted: Sun Feb 24, 2013 6:52 am
They never came with it. I.e. no provisions for it. I added it along with a Viper alarm. Couldn't be happier.
92 Pontiac Bonneville SSE | L67/4T60E | 77K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 190K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Summer Daily Driver
99 Chevy Tahoe LT | L31/4L65E | 238k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig and Portable Concert Hall
04 Cadillac Seville SLS | LD8/4T80E | 201k mi | Red Jewel Tintcoat w/Shale & Grey Int. | Nicest Beater Around
09 Chevy Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int. | Fuel Miser Daily
13 Ford Explorer XLT | 3.5/6F55 | 150k mi | Kodiak Brown w/Blk Int. | Unbreakable, somehow
James May wrote:
Hello.
PostPosted: Sun Feb 24, 2013 12:53 pm
Year and Trim: 2003 SSEi.
LOTS of Mods
No they didnt come with a remote start, I have added one to my SSEi that retains the Memory functions.
I got a Bulldog ( i think is the name), unit that can be configured to start the car based on the Factory remote Lock Pulses. The way it works is to Unlock the car then press lock 3 times with the key fob, and the car will start, with Either Number 1 or Number 2 key fob and retain all settings
PostPosted: Sun Feb 24, 2013 1:52 pm
Mine retains memory settings as well.
Aftermarket systems can be had at a decent price, but depending on exactly what you want they can be spendy.
James May wrote:
Hello.
PostPosted: Sun Feb 24, 2013 4:51 pm
88, 89, 91 SSE
89, 90 SE
Thanks guys! My first bonnie, an 89 se, had a bulldog RS, I installed it myself, but I'm not so confident on installing it on a 2002 with dual memory, though if instructions are clear, no problem.
PostPosted: Sun Feb 24, 2013 10:28 pm
The biggest thing is the range and features with the aftermarket fobs. My stock fobs only go like 100'. The good Vipers go miles, or unlimited if you get the setup that works off your phone.
PostPosted: Sat Mar 02, 2013 11:38 pm
88, 89, 91 SSE
89, 90 SE
Thinking I'd like a longer range too...
Any thoughts on the rest of my OP?
Update to my OP: Looks like I need to PM the ignition system, surging while on cruise control too...
PostPosted: Sun Mar 03, 2013 7:12 pm
I didn't know you could use the factory remotes, I didn't want a different remote. I had a remote start installed on the wife's car in Dec., hers' reaches 1200'
PostPosted: Wed Mar 06, 2013 8:35 am
Do you know what model your Bulldog system is? And what kind of range you get with their fobs?
Nate
Dark Blue Metallic paint
80k miles
PostPosted: Wed Mar 06, 2013 9:19 am
LOTS of Mods
This is the one that I installed
http://www.bulldogsecurity.com/Products ... ystem.aspx
I DO NOT use the Bulldog Fob. I use the factory fob to retain the memory settings
There are no new unread posts for this topic. HELP!!! 2 bonnevilles down
trab
Fri Feb 07, 2014 10:28 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Junkyards with any 00+ Bonnevilles?
Looong4
Sat Mar 14, 2009 2:18 pm
GoldenBullet View the latest post
This topic is locked, you cannot edit posts or make further replies. The fate of our Bonnevilles...
99BonnevilleSE
56
4188
Sun Feb 24, 2013 4:11 pm
repinS View the latest post
There are no new unread posts for this topic. Bonnevilles on 84s & vogues?
SwanginOn4z
26
12817
yourgrandma View the latest post
There are no new unread posts for this topic. Bonnevilles Unlimited
kennyz
Thu Aug 27, 2015 10:52 pm
jrbartholomew View the latest post
