It is currently Mon Jul 13, 2020 8:34 pm
PostPosted: Fri Nov 02, 2012 2:44 pm
Year and Trim: '98 LSS L67
So the LIM job has been done, and I'm left looking for the last part to complete the job.
Stolen image, not my car:
Removing this rubber tee from the manifold caused it to rip off the bottom portion of the tee, female, approx 1/4 inch inside. I'm sure this is a regular piece that needs replacement, but the dealer has informed me it is discontinued, so I'm looking at fabbing up an alternative with vacuum hose and a male tee if I can't find a suitable candidate from another source. I didn't have much success looking online, GMparts etc.
What sort of shops could I call here that might use this sort of fitting? It would be nice just to be able to pop one on instead of deleting the 2 hard lines come off of it as well.
Any tips appreciated. Cheers.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
PostPosted: Fri Nov 02, 2012 3:44 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
You could buy a generic T fitting and use vacuum hose to make "couplers"
PostPosted: Fri Nov 02, 2012 6:29 pm
Year and Trim: 90 SSE / L67 4T65E-HD
You could give this a try.... http://www.dormanproducts.com/p-17844-47415.aspx
90 Pontiac Bonneville SSE Series 2 L67/4T65-E HD [Frankenbonne 2.0] Swap complete, currently whomping on unsuspecting hondas.
85 Chevrolet Celebrity 2.8 2bbl/440T4
02 Ford Explorer XLT 4.0 SOHC/5R55
10 Mercury Milan Premier 3.0 Duratec DOHC/6F35
PostPosted: Fri Nov 02, 2012 7:39 pm
That looks close but I think its a bit small.
After calling all around town, I can't seem to locate the soft female type tee, so it looks like I'm just gonna have to fab something with a hard tee and some vac tubing and call it a day.
Thanks guys.
PostPosted: Sat Nov 03, 2012 3:00 am
That comes as part of the vacuum harness from the dealers. The thing that makes it odd is the 2 different sizes. Vacuum harness part number is 24508742 from GM.
PostPosted: Sat Nov 03, 2012 1:03 pm
Year and Trim: '02 SSEi
I bought the little $1.65 pack of tees and made it work. Didnt look great though.
PostPosted: Sat Nov 03, 2012 6:42 pm
I feel like an idiot. When I started the vac disassembly, I wondered about the function of a capped tee by the fire wall. After realizing my oversight, I swapped in a piece of straight tubing and the tee fits perfectly. Can't believe I didn't remember till I had hit 3 parts suppliers trying to find one. Flushing assorted fluids today, but everything is looking good! feels good to have the girl back on her feet! I'll post pics when I'm not so greasy, if you guys haven't seen enough LIM pics yet. :dontknow:
PostPosted: Mon Nov 05, 2012 12:22 pm
For those of you following along at home; the "T" is no longer sold separately but is still available as part of a "vacuum harness" assembly which is still available (see part number above). The "harness" contains this tee and two other rubber vacuum fittings, as well as the hoses that connect them. If you need to replace your tee, the other rubber fittings might be in sad shape also, so the harness is not a bad option. If cash is tight, however, and you don't mind cobbling together a substitute, some members (including the original poster apparently) have managed to make their own tee out of aftermarket parts. If, however, you like to replace everything with stock replacement parts, this post is for you.
Ken_W
PostPosted: Mon Nov 05, 2012 5:38 pm
Ken_W
I actually just raided the tee which I believe is a diagnostic access as far as I can tell, so I didn't have to drop any $$$ for any part. Being away from the motor at the firewall, it was in way better shape, and still good, although it is a 14 year old original.
Thanks all.
PostPosted: Sun Jul 28, 2019 7:30 am
Year and Trim: 2005 GP GTP
Thanks, all. I don't know how a simple tee can be discontinued so quickley (replacing/substituting mine in 2019).
'05 GP GTP
There are no new unread posts for this topic. Source for discontinued parts (rocker seals)
John Deere Boy
Sun Apr 06, 2014 5:58 pm
zuper8 View the latest post
There are no new unread posts for this topic. 93 bonneville alternatives
smithd2424
Fri Feb 05, 2010 8:37 pm
smithd2424 View the latest post
There are no new unread posts for this topic. Full paint alternatives
Bumzag
16
1649
Wed May 13, 2015 10:16 am
Bumzag View the latest post
There are no new unread posts for this topic. supercharger top vacuum tee oring
MattStrike
Fri Oct 26, 2018 9:28 am
There are no new unread posts for this topic. What controls vacuum on initial start and when AC is on?
Billha
Fri Sep 11, 2009 4:40 pm
J Wikoff View the latest post
