It is currently Sun Feb 17, 2019 9:41 am
 Post subject: 2000 Bonneville.
PostPosted: Sat Jun 23, 2012 2:24 pm
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
I've seen a nice looking 2000 Bonneville SE for sale, seems clean ans straight apart from rust bubbles on the back the hood, 106k miles and everything works.
Any weak points I should look out for, How do they deal with towing?, I will use it to pull my 1800lb caravan.
My current '87 Olds Delta 88 tows fine, but its engine gets on the torque curve at lower rpms, I know the Boony makes more torque, but at higher rpm.
Any information welcomed;
Roger.
 Post subject: Re: 2000 Bonneville.
PostPosted: Sat Jun 23, 2012 6:54 pm
The weakest point would be brakes and transmission. That can be addressed with a cooler and upgraded brakes. The other concern would be gearing. What is the gear ratio's of the cars? If you have a higher gear ratio in your current car, and a lower one in the new car, that puts you at a disadvantage, coupled with the different power characteristics, may be even worse.
Also, read up on the Upper and Lower intake manifold/gasket failures. That is the engine's weakest point, and can destroy it quickly.
As long as you know what you are doing, and address the concerns with towing that much, with a proper hitch it should do about the same if not a bit better than the Olds.
PostPosted: Sat Jun 23, 2012 10:58 pm
If you plan on towing with it, be sure to put a cooler in. Otherwise you will easily get trans temps over 200*.
PostPosted: Sun Jun 24, 2012 5:50 am
1989 Buick Le Sabre
Thanks guys, I appreciate your input.
I'm too late, the car has already been sold for more than I wanted to pay anyway.
I'll spend a little money keeping my Olds in good shape for a while longer, The windows need fixing but otherwise it runs well. I like it but the Pontiac was a better car, reflected in as much as I paid £600 for the Olds, the asking price for the Bonne was £3400.
Roger.
There are no new unread posts for this topic. 2000 bonneville se
wdudetocool
Wed Apr 25, 2012 7:01 pm
wdudetocool View the latest post
hi3150
Tue May 08, 2012 10:18 pm
There are no new unread posts for this topic. 2000 Pontiac bonneville
Bulldogfan
Sun Jun 26, 2011 12:36 am
There are no new unread posts for this topic. To Buy Or Not To Buy - 2000 Bonneville SSEi
Noah.Dreams
17
1943
Wed Jun 11, 2008 8:30 pm
Noah.Dreams View the latest post
There are no new unread posts for this topic. Looking to buy a 2000 bonneville sle white
glenn304bonne97
Fri Jan 20, 2012 12:00 pm
Ken_W View the latest post
