It is currently Thu Jul 18, 2019 3:50 pm
PostPosted: Mon Feb 13, 2012 3:47 pm
Well, the results from Blackstone came today in the mail. Unless there is something going on in the engine that can't be detected with an oil analysis, the engine should last at least 100,000 more miles. :banana: I posted the image from photobucket below. - BC
PostPosted: Mon Feb 13, 2012 3:54 pm
I think silicone is every reading I ever take. I attribute it to sealants too, but often wonder if it's something on the little plastic jug they give you. Nothing comes in contact with the oil as I stick the jug in the stream a few seconds after pulling the plug (to let it drain a bit before putting it in the stream). Then I'm careful to clean and seal the container.
PostPosted: Mon Feb 13, 2012 4:24 pm
That's exactly what I did - lol I did the oil change/new oil pan with the engine still very warm - BC
PostPosted: Mon Feb 13, 2012 4:43 pm
Looks great Bill! Goes to show that consistent care from the beginning has its benefits.
NVM, Blackstone is $25 an analysis. Ordered a test kit.
PostPosted: Mon Feb 13, 2012 5:42 pm
That is awesome news! Have you been using conventional or synthetic oil over the life of the car??
Eric
A few mods..
PostPosted: Mon Feb 13, 2012 5:51 pm
I think on one of my later oil analysis on the Bonneville, I got a "B" on Titan's grading scale for silicon. A being Acceptable, B being borderline, C being you better rebuild your engine (I suppose).
PostPosted: Mon Feb 13, 2012 7:02 pm
I paid the extra $10 to find out if leaving the oil in for 6 months was okay. Total cost was $35 for the test and $2.29 to mail it back to Blackstone.
The first 4 years or so I used conventional oil, but changed it every 3 months and added TX-7 once a year. Since then it's been all synthetic, but every 6 months. I currently use Walmart's 10w-30 100% synthetic. I did that about 6 years ago. Before that I used either Castrol 100% synthetic or Mobil 1 100% synthetic. I switched to Fram filters with teflon in them about 7 years ago until I saw they collapsed (that only happened because of information from here on the forum). Now I use either Microguard, AC Delco or Pure1. I need to find a teflon additive that is cost effective. - BC
PostPosted: Tue Feb 14, 2012 11:36 pm
For those who are interested; here is the report I posted at BobistheOilGuy.com last month. Silicon was noted here too, but was not felt to be an issue:
2000 Pontiac Bonneville SSEi
Series II 3800 supercharged engine
Valvoline MaxLife 5W-30 (regular MaxLife in red bottle, not NextGen)
Same brand oil was used in run prior to this one
4,874 miles on oil sample (oil was in use for almost 4 months)
170,218 miles in engine
Forgot to check the OLM for %
UOA was done at Blackstone Labs
Added 1 qt make up oil, 431 miles into run (4443 miles in run after top-off)
Driving is around 70% hwy / 30% city
Driving style is gentle-to-moderate
This was my first-ever UOA. I wanted to see how my hi-mileage engine is doing, and if I should replace my LIM gaskets. I do not think they are original, but I do not know how old they are. I bought the car in Dec 2010 at 152K miles and have been keeping maintenance up to date.
Code:
OIL             ML5w30   Univ Avg
MILES IN USE    4874     4600
MILES           170,218
SAMPLE TAKEN    12/17/11
ALUMINUM        4        3
CHROMIUM        1        1
IRON            10       13
COPPER          13       16
LEAD            4        7
TIN             0        1
MOLYBDENUM      144      65
NICKEL          0        0
MANGANESE       0        1
SILVER          0        0
TITANIUM        0        0
POTASSIUM       3        7
BORON           5        46
SILICON         24       11
SODIUM          348      38
CALCIUM         2060     2102
MAGNESIUM       9        79
PHOSPHORUS      741      690
ZINC            826      842
BARIUM          0        0
INSOLUBLES %    0.4      <0.6
WATER %         0        0
FUEL %          trace    <2
ANTIFREEZE %    0        0
FLASHPOINT ºF   365      >365
SUS VIS 210ºF   57.4     56-63
cSt @ 212ºF     9.47     9.1-11.3
TBN             3.2
Comments from Blackstone:
Quote:
The only reading out of line in this first sample from your 170,218-mile Bonneville's engine was
silicon. And silicon can be harmless or it can be abrasive. From the looks of wear, we'd guess it was a
harmless source (like a sealer or something that was used). Universal averages show typical wear levels
after about 4,600 miles for this engine type. Your wear numbers all look good compared to those averages.
A trace of fuel was found, but that's not causing any problems that we can see. The TBN read 3.2 showing
plenty of active additive left (1.0 is low). Try 6K miles.
PostPosted: Wed Feb 15, 2012 2:29 pm
Ken, Thanks for the post. I was hoping someone else would have input like this. To be honest, I really don't understand any part of the analysis except for the comments. I would sure like to know what the molybdenum means. I know at one time it the THE thing in lubrication, many years ago. I would also like to know what the rest means. From the comments on the TBN in your report, I think I could run my oil longer too. - BC
PostPosted: Fri Feb 17, 2012 7:59 pm
Year and Trim: 96 SSEi- 157K
Moly is awesome, it forms a coating to protect the moving parts. as you can see above Maxlife has quite a bit in it.
I am no expert but I know what some of it means... Aluminum, chromium, iron, copper, and lead are wear metals (which yours are not high), magnesium and calcium are detergents (a pretty good amount of calcium, that oil should keep things nice and clean), zinc is anti-wear and so is molybdenum of course.
walmart supertech synthetic certainly does well in your car, but unless you want the cold pumpability of synthetic, you would probably find that the stats on major brands of convetional oils are almost as good for less. you could also probably run those conventional oils for over 3K miles as well.
if you want to learn more this is a fun site I think and less daunting than BITOG for the basics:
http://www.pqiamerica.com/testresultssep2011.html
- Rachael
PostPosted: Sat Feb 18, 2012 1:23 am
Thanks for the input and help on some of the results. I followed the link, but I don't know which end of the chart is best high and which one is best low (lol). If I understood more, I guess it would be a good idea to switch to conventional oil since I don't run it for extended periods and typically don't do short drives. I need to search for more information to better understand the charts in the link.
off topic - that Bonneville of your's is looking great! - BC
PostPosted: Sat Feb 18, 2012 2:25 pm
Year and Trim: Currently searching for a Bonneville...
The oil life monitor on mine doesn't reach 10% or so, until 8 or 9 thousand miles. That used to make me nervous as I've never had a vehicle that went that long between changes, so I did one of those oil analyses just to make sure. I usually buy the cheapest oil I can find, as long as it has a newer API rating (SM or SN). Interesting that both oils thinned to a 10w-20 by the time they were changed.
Philips Trop-Artic 10w-30 SM:
Citgo Synthetic Blend 10w-30 SN:
Inferno Red 2009 Dodge Caliber SRT-4 125k
PostPosted: Sat Feb 18, 2012 4:06 pm
Looks like any GF5 oil can be run for a year if the short trips are run few and far between. Thanks for the posts. I'm still working on figuring out what's going on with all the analysis data. Nothing like a good mystery - lol - BC
There are no new unread posts for this topic. oil analysis? What does the 3800 Supercharged perfer
jethrow
12
2403
Tue Feb 10, 2009 12:06 pm
This topic is locked, you cannot edit posts or make further replies. Can I put green in a 96-99?
94SilverSSEi
Sat Oct 03, 2009 5:17 pm
repinS View the latest post
There are no new unread posts for this topic. Green curse
JMH1950
36
2493
Mon Dec 08, 2008 7:45 pm
JMH1950 View the latest post
There are no new unread posts for this topic. LED Swap from Green to Orange
jdronzek
17
2500
Thu Sep 17, 2009 9:13 pm
There are no new unread posts for this topic. Dale from Green Bay Wisconsin???
Skippy1827
Fri Aug 27, 2010 12:00 am
bonnelover View the latest post
