It is currently Wed Feb 20, 2019 9:29 pm
PostPosted: Mon Jan 16, 2012 11:24 am
Senior Moderator
Senior Moderator
Year and Trim: 00' SSEi
Geeze, this doesn't happen very often, but today, she didn't start. It was -12F this morning, battery seemed to have a good charge, all the lights came on, but click click click. So I unplugged the block heater and plugged in my battery charger. Will let it trickle charge all day while I'm at work. (I took the Explorer) I guess the battery could be run down just enough? The battery was new in August.
2016 GMC Sierra 1500 All Terrain. 5.3L 8speed
2000 Bonneville SSEi.
PostPosted: Mon Jan 16, 2012 12:15 pm
You need a battery warmer.
PostPosted: Mon Jan 16, 2012 1:12 pm
Senior Moderator
Senior Moderator
Maybe. I never had one last year, it started in -28F.
The true test is to come, Wednesday night we are going to dip down to -30F, going to feel like below -40 with the windchill (which wont affect my car) Going to head home in a bit, see if it starts, then take it to work and put it in the shop for the remainder of the day. More than likely, I left something on Friday night when I got home. This morning was the first time I went to use the car since Friday.
PostPosted: Mon Jan 16, 2012 1:16 pm
You also went from an optima to a cheapo battery, which can freeze...
PostPosted: Mon Jan 16, 2012 1:22 pm
Senior Moderator
Senior Moderator
I haven't ran an optima in years. Since 2008 actually.
PostPosted: Mon Jan 16, 2012 1:46 pm
Senior Moderator
Senior Moderator
Wasn't cheap either. Was 125 dollars.
PostPosted: Mon Jan 16, 2012 1:50 pm
Well, you know what I mean. If it still happens, I'd look into a battery heater...
PostPosted: Mon Jan 16, 2012 2:31 pm
Senior Moderator
Senior Moderator
Car is running. It isnt happy though.
PostPosted: Mon Jan 16, 2012 2:33 pm
Every battery becomes more prone to that as they get older. What's not happy about Damien's attitude?
PostPosted: Mon Jan 16, 2012 3:05 pm
Senior Moderator
Senior Moderator
Howling, barfin black *shoot* (as usual in sub -10F), I let it warm up completely. It smoothed out by the time it was warm.
PostPosted: Tue Jan 17, 2012 8:52 pm
Senior Moderator
Senior Moderator
Well, it did it again tonight. Went to start it at work, this time its -20F out...turned over a bit, then clicked. Battery was weak once again. Tossed the charger on it at work, and it started right up..in great protest once again. Going to have to leave an extension cord coming from the building to the car so I can atleast plug the block heater in.
It started good this morning, no problem, was plugged in all night though.
Tisk Tisk.
There are no new unread posts for this topic. 2005 Bonneville gxp won't start electric problem help!!!
Bluebonnie05
Thu Jun 30, 2016 12:25 am
There are no new unread posts for this topic. Start issue
1sik ssei
Wed Jan 02, 2013 11:49 pm
There are no new unread posts for this topic. Start with the IAC? ('02 Regal)
Bumzag
Fri Nov 20, 2015 1:45 pm
Bumzag View the latest post
There are no new unread posts for this topic. Did Bonnevilles ever come with OEM remote start?
phil0054
Wed Mar 06, 2013 9:19 am
There are no new unread posts for this topic. 2003 sle won’t start stumped :/
Tev373
Wed Feb 06, 2019 12:59 pm
Archon View the latest post
