It is currently Wed Jan 23, 2019 2:58 pm
 Post subject: Pulling the motor
PostPosted: Fri Jan 13, 2012 1:01 am
Year and Trim: 2001 SSEi
1991 SE
I beleave the easyest way is out the bottom, but how much harder is it to take it out the top? I already have most of the top end off, so the might make it better.
Thanks
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
 Post subject: Re: Pulling the motor
PostPosted: Fri Jan 13, 2012 2:42 am
The only way I would go out the bottom is if I needed the transmission out also. The problem with going out the bottom is getting the car high enough to drag it out.
I have done it twice on my car going out the top using Bill's hoist and it was only a couple hours from start to finish.
PostPosted: Fri Jan 13, 2012 11:58 am
We did a motor swap on the ZiLLA in 24 hours tear down to crank it up using that same hoist. Top is the only way to go if you don't want the trans out. Hell, even if you do. Bottom is only a consideration if you have a lift.
You have most of the top off? Don't forget you'll need to put your hoist brackets back on.
PostPosted: Fri Jan 13, 2012 5:07 pm
1991 SE
Do i have to take the hood off? How do you deal with the engine harness? Just unplug it from the firewall and take it out with the motor?
Thanks guys
PostPosted: Fri Jan 13, 2012 5:19 pm
Year and Trim: 99 SE
99 Suburban 2500 LT
68 Beetle
I'm not sure how different the harness layout is from my 99 to a 2k, but I just unplugged and labeled everything and pulled the harness out of the way. I think that you can pull the motor without yanking off the hood. Probably just have to have the hoist choked up close to the motor for the clearance needed to lift it high enough to get it out. It definitely makes it easier with the hood off though.
1999 Bonneville SE with the heart of a 07 Grand Prix
PostPosted: Fri Jan 13, 2012 8:14 pm
The wiring harness just moves out of the way once all the connectors are disconnected. You can label them if you want, but most of them just fall into place and have different connectors.
For the hood, just ise padding on the windsheild and unhook the struts/supports and lay it back. No need to remove it.
It also helps to have a second body to help with guiding it out and working the hoist.
PostPosted: Fri Jan 13, 2012 8:27 pm
Year and Trim: 1999 Bonne SLE
I didn't even unhook my hinges, used a regular engine lift. Unhooked all of the wiring harness and used a bungy cord to hold it back and out of the way while lifting the old motor out. 2 sets of eyes were barely enough, I hooked something on the softish rubber cover at the back of the bay and ripped it. Just go slow and watch carefully.
1999 DCM SLE- COTM Jan 2012
Planned mods... FWI, Exhaust and tips,Tinted all around
She's now gone:(
http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=8&t=31352&p=312104#p312104
PostPosted: Fri Jan 13, 2012 9:26 pm
Doing that with a 99 probably works, but with the 2k the firewall is closer and the engine with the hoist will not clear the hood and radiator opening. Been there done that twice, besides, the supports just pop off with a little pressure.
PostPosted: Sat Jan 14, 2012 2:25 am
1991 SE
So i can get away with out takeing the hood off, but i need to take the frount suport off?
PostPosted: Sat Jan 14, 2012 2:44 am
No, just like this, just make sure there is padding between the windsheild and hood:
PostPosted: Sat Jan 14, 2012 3:06 am
1991 SE
Wow, that helps. I have been trying to deside if i could do this myself in the gaurage. Now it looks like i can.
Thanks
There are no new unread posts for this topic. Pulling OBD 1.5
Bumzag
19
1395
Fri Jun 26, 2015 11:51 am
Bumzag View the latest post
There are no new unread posts for this topic. Trailer pulling
wlas
14
1257
Fri Mar 12, 2010 1:35 pm
Boss455 View the latest post
There are no new unread posts for this topic. changing valve springs without pulling a head
MattStrike
Fri Jul 29, 2016 11:13 am
Archon View the latest post
There are no new unread posts for this topic. motor mounts and....
RookieSSei
Mon Aug 25, 2008 9:29 am
There are no new unread posts for this topic. Best motor oil filter
xvr843
34
3110
Wed May 25, 2011 9:07 am
92BonneSE View the latest post
