It is currently Wed Jan 23, 2019 5:07 am
 Post subject: Water in trunk...
PostPosted: Wed Jul 02, 2008 12:36 am
Year and Trim: 1997 SSE
Yeh...it`s all coming back to me now! Had a 1994 Olds 88 that had the same mysterious water in trunk problem. Can you guys tell me where to start looking? here`s the lowdown....trunk seal appears to be in great shape and is flexible. I know water will drip in when lid is lifted, yet she seems to get water in there even if its not lifted up (after car wash) Possible leak through spoiler mounts? Body putty intact inside and no holes in trunk. Is this a factory problem with a fix? Anyone with the solution, please point the way.
Thanx. Chopper :???:
1997 SSE - Bright White -Gutted box, Overlays, GTA vents, cleared corners, calipers..so far.
 Post subject: Re: Water in trunk...
PostPosted: Wed Jul 02, 2008 1:37 am
There are lots of possibilities - lens gaskets, seal around the antenna, cracks or missing seam sealant, rear window seal failing, wheelhouse to trunk floor rust holes, etc.
The time-honored method for finding a trunk leak is to strip out the linings, crawl inside with a good flashlight and close the lid. Have someone slowly run a hose from the bottom up all around until you see where the water is coming in.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Wed Jul 02, 2008 3:11 am
Year and Trim: 06
Sun roof vents under the roof liner could be leaking which happened to me, it ran down the trim into the trunk, no water damage to the rest of the car, just puddles in the trunk.
PostPosted: Wed Jul 02, 2008 12:43 pm
Year and Trim: 2000 SSEi w/ 99K
taillights are the bane of my dry existance here in "it rains every day" Florida. stoopid pontiac..i am gonna drill some drainage holes soon..sigh
PostPosted: Wed Jul 02, 2008 7:25 pm
You all may benefit from reading through jr's3800 water leak thread. This stuff is pretty much covered there. I'll see if I can find the link.....viewtopic.php?f=19&t=176
PostPosted: Thu Jul 03, 2008 12:53 am
Thanks guys...I`ll check the sunroof vents tomorrow
and crawl in the trunk to check for tailight / seal leakage.
Interior is bone dry...everywhere, problem only in trunk.
This car is mint, with no rusting anywhere so it`s getting in
somewhere that isn`t obvious.
Think I`ll have a buddy help me out....my wife would leave me
locked in the trunk if she helped!
She would claim it was an accident.... :-k
PostPosted: Thu Jul 03, 2008 2:28 am
Year and Trim: 06
You could just try to squeeze through the door between the seats. :wink:
PostPosted: Thu Jul 03, 2008 7:12 pm
Recognized Vendor
Recognized Vendor
When you're looking, consider the trunk lip that holds the seal itself. I have a 2000 SSEi (I know, different trunk, but same problem) and I looked at ALL the suggested fixes. None were the problem. I decided to check the trunk lip seal. It wan't perfectly symmetrical on both sides. so I pulled off the rubber seal and bent the lip "up" just a little and put the seal back on. So far so good. Seems it's easy to bend the lip when leaning on the seal when putting things in and out of the trunk. I had this problem since I bought the car over a year ago.
Since it worked for me I thought I'd mention it. I wish you luck finding the leak, as this can be really frustrating.
Dan McCann
PostPosted: Fri Jul 04, 2008 12:23 pm
mine has an emergency release cable inside... i thought they all did
There are no new unread posts for this topic. 1996 Bonneville - Fire started in trunk by trunk release
hunt2cbr
Sat Oct 17, 2015 1:23 am
ddalder View the latest post
There are no new unread posts for this topic. Water ok?
EWC88
11
1406
Fri Aug 29, 2008 11:07 am
00ssei View the latest post
There are no new unread posts for this topic. Attachment(s) Well, she's gone...dead in the water
Katalystxxl18
32
3508
Fri Jul 27, 2012 10:04 pm
There are no new unread posts for this topic. Water under carpet
97beigebonny
Mon Aug 12, 2013 10:00 pm
1tinindian View the latest post
There are no new unread posts for this topic. trunk net
unclebubbaSE
Tue Nov 03, 2015 4:21 am
unclebubbaSE View the latest post
Users browsing this forum: Google [Bot] and 4 guests
cron
