It is currently Fri Jan 28, 2022 6:56 am
PostPosted: Fri Aug 05, 2011 9:21 am
Year and Trim: 2005 Pontiac Bonneville SLE
Hi; Hopefully I'm posting this in the right spot--I'm new at this. Anyway, I have a question.
Our 2005 Bonneville has a 3.8L Series 2 engine. My son's friend owns a 2005 Grand Prix with a 3.8L Series 3 engine and my son is a little confused. To show how much I know, I figured it was because one car is a Bonneville and the other a Grand Prix, which my guys tell me doesn't matter :dontknow:
My son was wondering if perhaps sometime during the production year it was changed. I told him that the experts here would be able to tell me and I would let him know :)
And a question of my own--what is the difference between Series 2 and 3?
Bergette
PostPosted: Fri Aug 05, 2011 9:29 am
The largest difference between the two is that the S3 is a drive-by-wire engine, with the intake manifold redesigned to reflect this. As far as the long block is concerned, the S3 has better rods and pistons. Physically, the two generations are interchangeable. In fact, the 2005 Bonneville and Impala are actually S3 engines with S2 intake manifolds ;)
BonneMe wrote:
PostPosted: Fri Aug 05, 2011 9:37 am
Thanks, I'll pass that along to my guys who will no doubt understand what that means more than I do :) I'm better at "computer language" than I am at "car language" but I hope to learn more as time goes by.
Bergette
PostPosted: Fri Aug 05, 2011 10:03 am
Your gas pedal on the Bonneville uses cables. Direct linked.
The gas pedal on the GP with the S3 uses a feedback electrical system that drives a MOTOR to open the throttle. No direct mechanical link.
The differences between the motors are extremely sparse. They are virtually identical.
PostPosted: Fri Aug 05, 2011 10:17 am
Thanks, I actually understand that :) I always feel out of my depth concerning all thing mechanical. I'm hoping that if I "hang around" long enough I will be able to understand a little "carspeak" someday. Appreciate the reply.
Bergette
PostPosted: Fri Aug 05, 2011 10:38 am
The series III came out in 04 with the Grand Prix, which was equipped with the electronic throttle. The Bonneville kept the Series II because it wasn't worth converting the Bonne to an electronic throttle for 2 model years.
The biggest difference between the motors is the Series III has stronger connecting rods, an aluminum upper plenum, which eliminated the leak point of the Series II, and it had a return-less fuel system setup.
There are no new unread posts for this topic. Series 2 to Supercharged Engine
Terry Cunningham
Thu Feb 13, 2014 6:36 pm
There are no new unread posts for this topic. exhaust ports series 1 vs. series 2
MattStrike
Tue Feb 10, 2015 6:10 pm
Z-type View the latest post
There are no new unread posts for this topic. Batteries 78 series (92-99) vs 100 series (00-05)
1oldman
Sat Jun 14, 2014 7:08 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Series 2 to Series 3 swap
RoddyEvans
Fri Oct 20, 2017 10:44 pm
kc9dre View the latest post
There are no new unread posts for this topic. 200 or 205 HP for the Series II?
mdinno
Sun Oct 04, 2015 11:44 pm
95naSTA View the latest post
