It is currently Fri Feb 15, 2019 5:22 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jun 06, 2008 7:00 pm
Okay, so I am doing my UIM, gaskets, and such. I got the UIM off without too much problem, but now I have no clue how to get the LIM off to change those gaskets. The book I have says "Remove bolts, pull off." If anyone could give me a hand as too how to take it off that would be great. I removed eight of the bolts and have no clue how many more there are.
I have not yet removed the tensionor pulley because it seems as though I would also have to take off the water pump, and would rather not do that as well. If I have too I will.
The only thing I have broken so far is my map sensor... stupid thing.
EDIT:
I am finished putting everything back together now. I start it up and it idles fine at the beginning. After a little while, the engine starts to rock more than it should.
Also, If I put it into Reverse, the engine shakes really bad, and there is a sqeaking noise from somewhere near the pully assembly. If I put it in Neutral, the car idles fine for a little while, then rocks and if I put it in Drive from Neutral, it does the same thing as reverse.
I also Have a blinking service engine soon light, so I will borrow an OBD II scanner tonight.
What could be causing the shaking and squeaking? My dad thinks one of the cylinders isnt firing due to a bad spark plug, or a fouled injector (which would seem the most likely to me). Would either of these cause the problem?
It sort of seems like something is wrong with my transmission, because it only happens when I shift into reverse or Drive.
Please help.
 Post subject: Re: HELP!!!!!
PostPosted: Fri Jun 06, 2008 7:03 pm
Did you get the hidden bolts, there's two. One's on the front left (fif in front of car, it's on the bottom right) and one on the back right (if you're standing in front of the car, it's on the top left)
When I did mine, I never removed the tensioner pulley, I just did the one elbow hooked to the LIM...
PostPosted: Fri Jun 06, 2008 7:05 pm
Well if they were hidden probably not. I will go check.
does anyone know how many bolts there are supposed to be?
PostPosted: Fri Jun 06, 2008 7:07 pm
I think there's ten, if you got 8 out...
PostPosted: Fri Jun 06, 2008 7:15 pm
okay found and removed the hidden bolts, where should I pull on the manifold to pull it off.
PostPosted: Fri Jun 06, 2008 7:57 pm
Pretty much anywhere you can grab it from will be fine. Keep in mind that you may get some coolant dripping down into the engine doing this. That is one of the reasons that an oil change is recommended after the intake gasket change. Did you drain down the coolant at all yet? If not, I would do that now, before you remove the manifold so that you have less water inside the manifold.
PostPosted: Fri Jun 06, 2008 8:12 pm
WoooOOOOOooo So I finally got the LIM off, and the porting actually looks pretty square already. Yep I drained about a gallon and a half of coolant out of it. I am about to put the LIM gasket back on and go from there.
I am planning on doing an oil change soon afterwards, and again in a hundred miles or so.
The reassembly begins!
PostPosted: Fri Jun 06, 2008 10:12 pm
You are getting rid of the Dex right? From where you are at right now, it is pretty easy to do :wink:
PostPosted: Fri Jun 06, 2008 11:22 pm
Get rid of that dex if it hasn't been done already! Is there any way to tell dex apart from other coolants?
PostPosted: Fri Jun 06, 2008 11:53 pm
Yep, it is red, and is also black light reactive.
-Joshua-
PostPosted: Sat Jun 07, 2008 12:13 am
Is it dark red or pink? I have pinkish stuff in now, is that dex?
PostPosted: Sat Jun 07, 2008 12:15 am
I wouldn't call it pink.
-Joshua-
PostPosted: Sat Jun 07, 2008 12:21 am
kinda looks like what i got, uh-oh, one more thing to have changed when it is at the shop next week
PostPosted: Sat Jun 07, 2008 12:40 am
Make sure they do a thorough flush, or that they fill with a coolant that mixes with with Dex. If you use the green Prestone and there's a significant amount of Dex still in the system, I have been told that it turns to a gel. They are not compatible. I had green stuff put in years ago when I did the swap. But, I think most guys here now use "mixes with any color" stuff.
-Joshua-
PostPosted: Sat Jun 07, 2008 12:44 am
Ok, thanks.
 Post subject: Re: More Help Please!
PostPosted: Sat Jun 07, 2008 6:24 pm
Grr checked all the plugs and they are in the right spots...
PostPosted: Sun Jun 08, 2008 1:12 am
Okay pulled the codes and it gave me a P0300 which is a Random/Multiple cylinder misfire. Which is good news (sorta) because it does mean that I either screwed up a plug, or fouled the injectors, which I now know how to replace (yay for learning through experience)
PostPosted: Sun Jun 08, 2008 1:35 am
Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired
laxmangl wrote:
EDIT:
Please help.
Double check that all the plug wires are on the right coils, and fully reseated on your coils and plugs; this could be causing your misfire(s). Also, could be that a wire(s) got broken during removal, if they were really tight on the plugs...any chance of that? If you own an old-fashioned inductive timing light, checking that each wire is conducting would be easy enough.
Also, how is the MAP sensor broken? Is it the clip(s) that hold it in place? If so, maybe you've got a vac leak there. Could be causing your rough running and your squealing sound.
Finally, did you make sure the PCV valve o-ring is properly seated? Leaving that out would definitely cause the squeal. You can check that by seeing if there is vacuum (there should not be) at the oil fill cap--pull off the cap while running the engine and put your palm over it to check.
Bone Stock
Retired
PostPosted: Sun Jun 08, 2008 2:42 am
Thanks a TON. Okay, the wires could have been damaged, I will check that, the map sensor broke when I pulled it out, i pulled straight up, and all I got was the square part (the part that was in the hole stayed in the hole), I will check to make sure that is seated properly as I wasnt sure about that in the first place. And I will also check the pcv valve o ring.
Thanks A TON for the help
PostPosted: Sun Jun 08, 2008 8:01 pm
Okay so after all that it turns out that mixing up some plug wires REEALLY makes your engine run funny...
There are no new unread posts for this topic. I think i made a big mistake...
seekinhighhp
Sun May 01, 2011 11:28 am
wake View the latest post
There are no new unread posts for this topic. bought a 2002 Ultra today - did I make a mistake? (Update)
Billha
30
3024
Fri Mar 18, 2011 4:36 am
There are no new unread posts for this topic. seriously stupid question......
Luxrain
Wed Jun 08, 2016 2:40 pm
Luxrain View the latest post
There are no new unread posts for this topic. Really stupid move (on my part)
skregal
Mon Jun 09, 2014 9:43 am
Sirius View the latest post
There are no new unread posts for this topic. Probably a stupid qustion about wheels/rims
94SilverSSEi
Mon Jul 07, 2008 7:29 pm
BonneMe View the latest post
