It is currently Tue Apr 16, 2024 1:36 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Thu Nov 19, 2009 2:18 pm
05 Mercedes S500 4Matic
I used a bit like this one in my Dremel to knock off the plastic alignment channels and to narrow the center tab: http://www.lowes.com/lowes/lkn?action=productDetail&productId=94703-353-194-03&lpage=none&cm_mmc=search_gps-_-gps-_-gps-_-Dremel%20High-Speed%20Cutter
`05 Mercedes S500
PostPosted: Thu Nov 19, 2009 7:16 pm
Year and Trim: 1999 buick park ave 1996 chevy caprice 9c1
DONE! a little bit brighter I noticed, I used a propane torch and a small flat head screwdriver and just heated the tip,very easy and simple Thanks guys!
PostPosted: Fri Nov 20, 2009 4:27 pm
Done. The quickest mod I've done yet. Used a dremel. 5 hours till dark. :banana:
PostPosted: Fri Nov 20, 2009 6:33 pm
Recognized Vendor
Recognized Vendor
If someone was really smart they'd make a harness to convert the 9006 plug to 9005, A 9006 Female end and a 9005 male end. Then it would literally be plug & play!
Plug and play on the wiring only. You still need to remove part of the top tab to have it fit in the socket.
Truthfully, this is so easy, I don't see the need to go to the trouble for the wiring. It's just another added point of failure if anything goes wrong with the adapter. I lost a passenger side light couple weeks ago. Stopped at Pep Boys and in 5 minutes, had the bulb modded and installed right there in the lot. Piece of cake. Mmmmm...caaaake *drool*
Dan McCann
PostPosted: Fri Nov 20, 2009 8:13 pm
I actually didn't cut the top tab when I installed mine. I was wondering why they were tough to get out when I swapped them. I may have to cut that little bit off.
PostPosted: Sat Nov 21, 2009 11:40 am
Tried the new 9005 night hawks high beams in the low beam sides of the 94 and WOW, I can see again!!!
Very noticeable improvement. Before, I honestly couldn't tell they were on, most of the time.
:banana: :banana:
Got to do this in the 00 now.
PostPosted: Sat Nov 21, 2009 12:02 pm
Glad you liked the mod Paul. :)
Now, what the hell took you so long to do it :bstooges:
Its nice to see the deer(you do have deer where you live don't you) at night a little sooner so you have more time to do what you have to do to miss them.
ROD
p.s. why don't you become the first to put the HIR bulbs in the '00 =D>
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
PostPosted: Sat Nov 21, 2009 12:43 pm
I am done with modding for the sake of modding.
The lights were a necessity. Since we are now using the Grizz as a DD, it was necessary.
The Bullet remains waxed and spotless in its garage next to the Firebird, until March sunshine returns. :wink:
The only mods I will be doing from now on will be required maintenance mods.
It tooks me so long because I had just replaced all eight bulbs on both Bonne's with Silverstars. Those suckers are over priced. I was waiting for them to burn out.
Unfortuneately for me it will take 10 years at the rate I have them on. :roll:
Speaking of required maintenance, anyone ever tried a powered trunk opener? That trunk lid on the Grizz is heavy with only one working spring.
PostPosted: Sat Nov 21, 2009 4:00 pm
Paul, why haven't you replaced the broken spring? I was able to get it as a dealer part when mine broke a year ago.
`05 Mercedes S500
PostPosted: Sat Nov 21, 2009 4:45 pm
I thought you might have seen my other post.
No. The part is no longer stocked. Anywhere. :angry4:
I snatched a complete assembly out of an Olds but the springs are smaller and I don't think will handle the heavy SSEi lid.
Does anyone notice that the drivers side light is not parallel to the passenger side?
I had them professionally aligned at the dealer last year.
The high beams are aligned and they are in the same housing as the low beams....wtf!?? :ack: :???:
PostPosted: Sat Nov 21, 2009 5:44 pm
I noticed that too. I think it's to avoid blinding other drivers. When your highs are on, there's not supposed to be oncoming traffic.
PostPosted: Sat Nov 21, 2009 5:57 pm
Yes I know the low beams normally point right but it appears that the factory has also biased the left front to go left more than the right. So they both converge on the same spot but the high beams go to infinity.
To be honest I don't like the high beams on the 94 cause they are almost useless at seeing anything 100 feet in front of the car. :angry4:
PostPosted: Sun Nov 22, 2009 12:22 am
When I did my HID's and got really crazy with aiming them properly, I noticed that they seemed to be really biased towards the right. Maybe it's just the kit, but I had to adjust them a fair amount to get everything centered up properly.
-Dan
_
_
There are no new unread posts for this topic. 9005 for low beams
bonnevillain
18
3292
Mon Oct 27, 2008 1:21 pm
rrounds View the latest post
There are no new unread posts for this topic. /.82 = whp to chp conversion.
MadMike
20
3642
Thu Aug 26, 2010 8:08 am
willwren View the latest post
There are no new unread posts for this topic. Conversion Kits
jradke61
Thu Dec 08, 2016 12:24 am
redfury View the latest post
There are no new unread posts for this topic. Exterior led light conversion 01 ssei
Kevg
Wed Oct 06, 2021 2:29 pm
Kevg View the latest post
There are no new unread posts for this topic. Hypothetical question: Manual Transmission Conversion?
LeSabre in Buffalo
Mon Sep 06, 2010 9:11 pm
repinS View the latest post
