It is currently Sat Sep 26, 2020 5:26 pm
PostPosted: Thu Aug 27, 2009 2:47 pm
Year and Trim: 97 White Ei 197K
97 Black SE/SC 185K
If an engine over heats, will the excess heat ruin valve springs?
PostPosted: Thu Aug 27, 2009 3:09 pm
No. The temp needed to make the spring loose it's temper is much higher than anything the engine can generate, unless it is on fire.
Mostly an overheat creates a leaking head gasket, or at worst the piston seizes in the bore and then breaks up. This is about the only overheating failure that results in valve or spring damage (Valve getting hit with a chunk of molten aluminum, knocks the retainers out, valve drops, and spring rattles around in the top of the valve cover...assuming the engine keeps running long enough after dropping the valve.)
PostPosted: Thu Aug 27, 2009 4:58 pm
97 Black SE/SC 185K
Cool, thanks :)
There are no new unread posts for this topic. changing valve springs without pulling a head
MattStrike
Fri Jul 29, 2016 11:13 am
Archon View the latest post
There are no new unread posts for this topic. Spotted a fellow Bonnie in the wild out in Palm Springs...
Ramcharger310
Thu Jan 02, 2020 1:33 am
Ramcharger310 View the latest post
There are no new unread posts for this topic. front stuts springs make huge gap between tire and fender
mybonnelou
Thu Dec 01, 2016 2:01 am
There are no new unread posts for this topic. EGR valve
postalba
Mon Jan 30, 2012 9:42 pm
There are no new unread posts for this topic. Location PVC valve
coolbluecar
Sat Nov 24, 2012 7:44 pm
