It is currently Wed Jan 23, 2019 1:59 pm
 Post subject: Trunk air compressor
PostPosted: Tue Mar 17, 2009 1:53 pm
Year and Trim: 97 Bonneville SSE.
:helpsmilie: Hey guy's. Not sure if my air compressor is working like it should. What all is tied into it (rear shock's etc.) or is it just for airing up your tires? :banana:
Sony MDX-C7900 running thru Bose system-CD changer in trunk-XM-Infinity tweeters. Autolite APP 605 plugs. New left lower control arm. New water pump, ICM, Crank sensor, MAP,TPS. Working on 2nd engine. Adding to car all the time.
 Post subject: Re: Trunk air compressor
PostPosted: Tue Mar 17, 2009 1:59 pm
It's tied to the rear struts. It'll run automatically to pump them up if the rear gets too low.
If you hit the on button, it only sends air to the inflater next to it.
PostPosted: Tue Mar 17, 2009 2:14 pm
:bsnicker: Is the air compressor loud enough to hear when it comes on? I might need a new one cuz I never heard it work. The button goes click on the inflator panal but no sound from pump.
PostPosted: Tue Mar 17, 2009 3:35 pm
Year and Trim: 1999 SSE
Search this forum regarding the issue. There have been numerous posts on how to diagnose and fix the problem.
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
PostPosted: Tue Mar 17, 2009 4:15 pm
If I remember right, your compressor should be hiding near the right rear fender well. I'd think you'd hear it when you turn it on.
Please post back if you can't find the answers in another thread.
PostPosted: Wed Mar 18, 2009 7:58 pm
Year and Trim: 98 SSEi
ignition key needs to be in acc or on iirc.
PostPosted: Wed Mar 18, 2009 8:00 pm
turn the key on, open the trunk, and sit on the back of the car. have a friend sit with you if you can.. it should come on to level the car.
PostPosted: Wed Mar 18, 2009 8:32 pm
You may have to sit there for a minute.
PostPosted: Mon Mar 23, 2009 7:22 pm
you should her the pump no problem. It will make a wrrrr sound
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
There are no new unread posts for this topic. Viair compressor in replacement of OE air compressor
RogueSSEi
Wed May 02, 2012 5:33 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. 1996 Bonneville - Fire started in trunk by trunk release
hunt2cbr
Sat Oct 17, 2015 1:23 am
ddalder View the latest post
There are no new unread posts for this topic. Air Compressor
wowzer
Sat Apr 28, 2012 12:18 pm
There are no new unread posts for this topic. AC Compressor
94SilverSSEi
Tue Jul 02, 2013 10:04 pm
95bonnypixiegray
Sun Aug 12, 2018 11:58 am
96 SSEi View the latest post
