It is currently Sat May 25, 2019 5:31 am
 Post subject: Snout Seal?
PostPosted: Wed Feb 18, 2009 3:55 pm
1992 Bonneville SSEi (Sold)
Hi
I got a new snout seal when i got a my new coupler hoping to install them this weekend before i start driving again.
My question is there a special way to do it, do i need to know any tricks or things to worry about, Ive never done a snout seal before i just wanted to check before i did it just in case theres i might miss.
Thanks Keith
2001 SSEi Bumbles
 Post subject: Re: Snout Seal?
PostPosted: Wed Feb 18, 2009 3:57 pm
define "snout seal"
There are no actual gaskets used in the assembly of the M62 supercharger.
Just use anaerobic gasket maker.
-Andrew-
PostPosted: Wed Feb 18, 2009 4:10 pm
Its at the end of the snount the pulley end from what i remember.
http://www.rollingperformance.com/scoil.htm
Here is the one i got if u scroll down alittle
2001 SSEi Bumbles
PostPosted: Wed Feb 18, 2009 4:19 pm
Oh, you are rebuilding the nose drive also? You'll need a hydraulic press.
Unless your nosedrive is leaking, just a simple coupler change is probably all you really need.
-Andrew-
PostPosted: Wed Feb 18, 2009 4:25 pm
Its not leaking or anything. I cant hear the couple rattling around, i just figured that while i was there i would replace that seal to i didnt know that i would have to rebulid it maybe ill just do the coupler for now cause i dont have acess to a press any more.. I would like to rebuild it later down the road.
2001 SSEi Bumbles
PostPosted: Thu Feb 19, 2009 12:20 am
If there's no issues w/ it, I say leave sleeping dogs lie.
PostPosted: Thu Feb 19, 2009 1:30 am
Year and Trim: 1996 SSEi
save the seal for when this one fails all it is is a spring clip that fits in a groove in the end of the snout so step by step:
remove nut on the end of he pulley
remove the pulley
remove the spring clip
remove seal
install is the reverse of the above steps
p.s. the seal tends to get destroyed on the way out i took mine out by drilling two screws opposite of eachother to pry against. reason being i wouldn't score and damage the snout walls.
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread http://pontiacbonnevilleclub.com/forum/viewtopic.php?f=27&t=15185
PostPosted: Thu Feb 19, 2009 9:08 am
Yes, it's possible to change it with the procedure above, but it can get ugly. If it's not leaking yet, it's best to leave it for now.
PostPosted: Thu Feb 19, 2009 10:07 am
Doesn't seem to hard but Im just leave it alone for now untill its starts to leak or a rebuild.
Im glad i asked before i tried to do it thou one less thing to do these weekend. :wink:
Thanks for the help
keith
2001 SSEi Bumbles
PostPosted: Thu Feb 19, 2009 6:43 pm
Year and Trim: 1999 SLE 112,000mi
2002 Park Ave Ultra 88,000mi
If you later decide to replace the snout seal, I know how to do it without removing the snout from the supercharger and using a press. I've done it on 3 different M62 units of mine, all with success, but it took a bit of creativity and care. I bought Viton seals; the OEM seals are Teflon and have an odd sprialing groove that I've never seen on any other seal.
PostPosted: Fri Feb 20, 2009 12:28 am
Viton is a bad idea for most high-mileage M62's. Over time, the original seal will actually wear a groove in the shaft. Viton is less flexible, and takes a LONG time to 'seat' in the grove of the input shaft. Nitrile should be the primary choice of any M62 still on the road. Your chances of leaks are far less, and it will easily outlast your ownership of the car for less money.
There are no new unread posts for this topic. Snout seal failure-->psi loss
6sic6
Fri Sep 26, 2008 1:43 pm
6sic6 View the latest post
There are no new unread posts for this topic. Anyone want to help me replace my Supercharger snout?
Z-type
Wed Aug 19, 2009 4:39 pm
Z-type View the latest post
There are no new unread posts for this topic. Supercharger snout leak?
Smithw500
Fri Apr 20, 2018 3:10 pm
There are no new unread posts for this topic. Gen 3 Gen 5 M90 snout rebuild vids
Backhoe
Mon May 13, 2013 4:35 pm
Backhoe View the latest post
There are no new unread posts for this topic. GM sealer for supercharger snout
Ultra Boost
Fri Sep 05, 2008 1:34 pm
willwren View the latest post
