It is currently Sat May 25, 2019 4:49 am
PostPosted: Wed Sep 24, 2008 11:21 pm
Year and Trim: N/A
Howdy. Newb to the site
Few questions. Could boost from the lobe housing somehow have found its way into the snout?
I was doing some fuel tuning (MegaSquirt) the other day. I was in the top of 3rd gear at about 14psi and I almost instantly went from boost to full vac on my gauge. I pulled over assuming I lost the belt, pop'd the hood and oil was all over my belts, hood, and even my wheel's inside.
I tracked the the oil to being from the blower. It leaks from the snout only when turning.
On the drive home she would only build about 8psi. Is this most likely from an oil coverd slippy belt? Or is this sudden seal failure related to the boost loss other than slicking up the belt?
Regardless I orderd a snout rebuild kit from rolling performance. I havent removed the blower yet but Iam fearing the worst. Atleast Ill have a rebuild kit if I end up buying another M62.
PostPosted: Wed Sep 24, 2008 11:23 pm
which end of the snout?
-Andrew-
Year and Trim: N/A
Sry, pulley side
PostPosted: Wed Sep 24, 2008 11:37 pm
I'd guess it's just from belt slip. You'll probably want a new belt.
PostPosted: Fri Sep 26, 2008 12:16 am
Year and Trim: N/A
Could boost have somehow got into the nosedrive?
PostPosted: Fri Sep 26, 2008 9:20 am
You'd have to have a rotor plate bearing failure of some sort. If yours still turns fine, I doubt it's a problem.
If there's rotational play in the pulley, you'll need a coupler, by the way. If there's no wobbling, grinding, or play, you may just need a new nosedrive shaft seal. There's two kinds, nitrile and viton. I'd get the cheaper of the two. It seems to "seat" better and won't leak as much off the bat.
PostPosted: Fri Sep 26, 2008 10:48 am
Year and Trim: N/A
*dang*, I have a rebuld kit with the "Viton" seal on the way.
PostPosted: Fri Sep 26, 2008 10:54 am
Well, give it a shot. Just because it didn't work for me and a few others, doesn't mean it'll fail you.
PostPosted: Fri Sep 26, 2008 1:17 pm
Year and Trim: N/A
Shes full of metal paste. I drained the fluid today. Clumpy and metalic.
PostPosted: Fri Sep 26, 2008 1:23 pm
That sounds like bearing failure. If the goo got to the seal, it could tear it and leak. Hope it's the nose drive bearings and not the rotor plate bearings. Those are impractical to replace.
PostPosted: Fri Sep 26, 2008 1:43 pm
Year and Trim: N/A
Its weird. Everything turns fine. No binding or noises. Ive never changed rotor bearings before. These bearings now arent that old. I changed them along with the coupler and snout seal about a year ago and prob only 1k miles.
There are no new unread posts for this topic. Snout Seal?
irish91983
Fri Feb 20, 2009 12:28 am
willwren View the latest post
There are no new unread posts for this topic. Anyone want to help me replace my Supercharger snout?
Z-type
Wed Aug 19, 2009 4:39 pm
Z-type View the latest post
There are no new unread posts for this topic. Gen 3 Gen 5 M90 snout rebuild vids
Backhoe
Mon May 13, 2013 4:35 pm
Backhoe View the latest post
There are no new unread posts for this topic. GM sealer for supercharger snout
Ultra Boost
Fri Sep 05, 2008 1:34 pm
There are no new unread posts for this topic. Supercharger snout leak?
Smithw500
Fri Apr 20, 2018 3:10 pm
