It is currently Mon Feb 24, 2020 1:36 pm
PostPosted: Thu Sep 05, 2019 7:28 am
Year and Trim: 2002 Pontiac Bonneville SSEI
New to the group here. I have a 2002 Bonneville SSEI. Just noticed when rolling downhill yesterday that my boost gauge shot up to 0psi. I had my foot on the brake, not the gas. I parked and let it idle when I got home and the boost gauge was jumping around erratically. I would normally think it's just the stepper motor in the dash, but you could hear a change in the way the car ran. Then, it shut off on its own. Anyone had something similar? If so, how was it fixed? Thanks!
PostPosted: Thu Sep 05, 2019 8:02 am
Could be a vacuum leak in the boost control actuator or lines leading to it. Or the manifold air pressure sensor is going bad, or... the wiring to it.
There are no new unread posts for this topic. Boost Gauge Tap on L36
ChibiBlackSheep
Tue Sep 30, 2014 8:08 pm
There are no new unread posts for this topic. BOOST PSI gauge
David CO
Sun May 31, 2009 5:21 pm
David CO View the latest post
There are no new unread posts for this topic. Boost gauge reads 0 PSI.
Boreas
Wed Aug 01, 2012 10:17 pm
There are no new unread posts for this topic. Low Boost
danseaview
Thu Oct 25, 2012 9:15 pm
danseaview View the latest post
There are no new unread posts for this topic. No boost
dave1003
Tue Apr 19, 2011 1:17 pm
