It is currently Fri Mar 22, 2019 5:52 am
PostPosted: Tue Mar 13, 2018 5:16 pm
......so has anyone found any info on this Australian set up?
It works amazing for him and the Demon uses a similar system......
PostPosted: Tue Mar 13, 2018 5:54 pm
G8 guys run it. They're running ZL1 or Magnuson setups predominantly, and they seem to work great. Outlet temps at or lower than ambient even running down the highway. Not sure how you'd hook it up on a Bonne though, and it's as much money as the blower itself, or in this case, any 2000+ Bonneville.
PostPosted: Wed Mar 14, 2018 2:41 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I remember at one point when I was younger, I thought about using A/C in place of an intercooler, and was made fun of or told I was being over-complicated, or some such. :bhuh:
Runs:
Doesn't run:
PostPosted: Mon Mar 26, 2018 9:26 pm
You're wise beyond our time, Matt.
