It is currently Thu Jun 04, 2020 1:25 pm
PostPosted: Fri Apr 28, 2017 9:08 pm
Hay guys! Got a lot of great help so far with problems on my recently purchased 2000 Bonneville SSEI.
Not sure if I have a problem or not so need some feedback. This is my first factory supercharged car. Had some minor issues that were traced back to vacuum leaks. Stopped at the local GM dealer and found that all the factory formed vacuum lines and rubber connectors are still available for this car so I purchased them figuring they'd be better than aftermarket products. Installed them and the car runs great. Only thing I noticed now is I don't hear the supercharger whine like it did before the new vacuum lines. Boost gauge is still reading correctly and changing as it should based on load and throttle position. Getting up to almost 10psi of boost with full throttle as per the gauge, and the engine sounds real good but no noise I can hear inside the car from the supercharger. Is this normal for this car when it is running properly or is there something I should check or repair?
PostPosted: Sat Apr 29, 2017 11:49 am
The stock intake blocks the whine pretty well.
PostPosted: Sat Apr 29, 2017 1:05 pm
I did see a lot of people saying the aftermarket intakes make the supercharger more noticeable. I guess I'll find out soon. Was thinking about getting the stage II kit from zzp performance that includes the new air box.
PostPosted: Sat Apr 29, 2017 3:24 pm
2003 SSEi
2004 GXP
10psi is actually higher than stock 7.5 - 8.0 psi. You might not have a stock 3.8" diameter pulley if your actually getting 10 psi.
02 SSEI, 1.94 Yella Terra,Gen5 , N*,2-1/4""Phenolic Intercooler,
I SELL, Phenolic Intercoolers, Pulley Pullers, Throttle Bodies, Etc...!!
PostPosted: Sat Apr 29, 2017 4:28 pm
Well I didn't check it with a real gauge I'm only going by the factory boost gauge on the dash. Just wanted to make sure everything was normal since I didn't hear anything anymore. Read on a previous post that air temp and density have a lot to do with it as well.
PostPosted: Sat Apr 29, 2017 5:44 pm
ON MY 2000 SSEi, 70 kpa is max which converts to approx 10 psi so I would assume that is normal.
PostPosted: Sun Apr 30, 2017 9:32 am
2003 SSEi
2004 GXP
Is that the Max you see on the Gauge? Does you needle actually point at 70 kpa or 10 psi while running?
PostPosted: Sun Apr 30, 2017 9:53 am
Well it will point to 10psi briefly under load at full throttle. But then will drop when I let off the throttle.
PostPosted: Sun Apr 30, 2017 11:34 am
It should drop when you get off the throttle. It should stay pretty steady at max output when you have the gas floored.
There are no new unread posts for this topic. Supercharger Oil
wolfie3491
Mon Mar 07, 2011 1:45 pm
wolfie3491 View the latest post
There are no new unread posts for this topic. supercharger
bobates
Mon Sep 06, 2010 9:47 am
willwren View the latest post
There are no new unread posts for this topic. supercharger oil
sqela
16
6134
Wed Aug 12, 2009 7:04 pm
awood35 View the latest post
BestBonnieYet
Wed Jun 08, 2011 10:37 pm
There are no new unread posts for this topic. Supercharger oil
rynmcdonald
Thu Sep 19, 2013 7:43 pm
