It is currently Mon Jul 13, 2020 9:32 pm
PostPosted: Sat Nov 29, 2014 5:03 pm
When I put a decent throttle and generate boost the engine misfires. I can lay off the throttle slightly and the misfire will subside and I do not throw any OBD2 codes. Today I removed the S/C belt as a test and under full throttle, to red line, there was no misfire. I recently replaced the plugs with AC Delco 41-101 and last year I replaced the fuel pump with a Airtex E3535M fuel pump and fuel filter at the same time.
If I am only misfiring under boosted conditions I suspect either a lean condition (fuel pump not keeping up), possibly the fuel filter (only a year old) or maybe even spark plug wires. I am just baffled that without the S/C belt (running without boost) there is no misfire under full throttle...car ran fine.
Thanks,
Chris
:dontknow:
PostPosted: Sat Nov 29, 2014 5:04 pm
This does not happen when parked and revving the engine. It only happens when driving.
PostPosted: Sat Nov 29, 2014 5:24 pm
When was the last time the plugs and wires were done? Ignition coils and ICM?
PostPosted: Sat Nov 29, 2014 6:33 pm
I just checked the wires after making this post, they look original. I will change them and see what happens. I was surprised when I saw "Packard" stamped on the wires with other factory labeling.
PostPosted: Sun Dec 14, 2014 7:50 pm
I replaced the spark plug wires while also replacing the LIM gaskets. OPTEST SAT!
PostPosted: Sat Jun 27, 2015 4:15 pm
Year and Trim: 2000ssei
Did you ever figure this out i have the same problem and have tryed everything i can think of. I dont know what else to try? :dontknow:
PostPosted: Thu Sep 24, 2015 5:35 pm
Year and Trim: 2000 SSEI
Do you have a way to scan the computer for a missfire per cylinder.. most hand held scanners will do it, might check into an App for your smart phone and a blue tooth OBDII dongle (like $25 on ebay).
If you can scan it you will have a Misfire count per cylinder and you will know where to start.. Bad Plug (i had one cracked out of the box) bad plug wire, Bad ignition coil, Bad Ignition control Module (ICM). Mine had a miss when under a load/boost and NEVER showed a missfire code, but when i scanned it with my tuning software it did report that my Cyl #3 was missing alot.. found hairline crack in the porcelain of the plug. replaced the plug and fixed my problem in my case..
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Sep 25, 2015 9:25 am
Just a thought, observe the engine while idling in a very dark garage. Use your hand to operate the butterfly on the throttle body and see if there might be any "stray" ignition spark under the hood. Probably not the cause, but you'd be amazed at what you discover doing this sometimes. - BC
PostPosted: Sun May 08, 2016 6:15 pm
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Clogged converter? I've had 2 instances where a clogged cat caused misfires.
"Big 3", Tint
PostPosted: Sun May 08, 2016 6:25 pm
hi, unplug MAF and see if issue changes - it will throw dtc po102
There are no new unread posts for this topic. Boost?
irish91983
12
1957
Thu Jun 17, 2010 1:11 pm
irish91983 View the latest post
There are no new unread posts for this topic. low boost
irish91983
12
2625
Wed Aug 08, 2012 1:33 pm
There are no new unread posts for this topic. Low Boost
danseaview
Thu Oct 25, 2012 9:15 pm
danseaview View the latest post
There are no new unread posts for this topic. No boost
dave1003
Tue Apr 19, 2011 1:17 pm
There are no new unread posts for this topic. Too much boost?
BonnieBoy08
12
2100
Fri Jun 07, 2013 9:04 am
BonnieBoy08 View the latest post
