It is currently Sun Feb 17, 2019 8:15 am
 Post subject: Vac Tree on Supercharger
PostPosted: Wed Oct 09, 2013 6:07 pm
Senior Moderator
Senior Moderator
Year and Trim: 00' SSEi
So today I replaced my supercharger with another. The original one that came with the car, its in good shape, nice and quiet. After replacing it, I started the car and now it doesn't idle well, its hunting. I found the tree on the top of the supercharger (one with the brake booster line connected) to be leaking quite good. I took it off, its missing the o-ring. I looked at my old one, it has no o ring either, infact that one I siliconed one. So I thought, hey I did it once, it worked, I will do it again. No difference, still leaks. I might have an extra at home, I'm not sure...I haven't called GM yet, but does anyone know if silicon is a bad idea here? Should I try to locate an o-ring?
2016 GMC Sierra 1500 All Terrain. 5.3L 8speed
2000 Bonneville SSEi.
PostPosted: Fri Oct 11, 2013 8:47 am
Senior Moderator
Senior Moderator
I found my problem yesterday. The EGR stove pipe was damaged were it makes the connection to the LIM, making a massive vacuum leak. Part will be here from GM today so I can replace it. I also ordered that Vacuum tree and seal on the top, seal for the vac tree on the side of the SC (96-97 special), and all OEM vacuum lines under the hood. These were cheap as heck, and will be here next week.
There are no new unread posts for this topic. 98 sse add a supercharger?
algore
Mon Nov 24, 2014 12:17 am
There are no new unread posts for this topic. hot Supercharger
blackbeauty00
Thu Feb 10, 2011 11:27 am
willwren View the latest post
There are no new unread posts for this topic. Supercharger oil
rynmcdonald
Thu Sep 19, 2013 7:43 pm
There are no new unread posts for this topic. supercharger oil
sqela
16
5702
Wed Aug 12, 2009 7:04 pm
awood35 View the latest post
bobates
Mon Sep 06, 2010 9:47 am
