It is currently Sat Jul 20, 2019 4:50 pm
 Post subject: Supercharger Oil
PostPosted: Tue Jun 07, 2011 12:33 pm
Year and Trim: 2003 SSEi
I have a 2003 SSEi with 135k miles. I have never serviced the supercharger. I have the car at the dealer today for an AC issue and I asked them to change the supercharger oil while it was in the shop. They told me there is no drain plug and that the oil never needs changed. Sounds odd to me. Is this true?
 Post subject: Re: Supercharger Oil
PostPosted: Tue Jun 07, 2011 12:40 pm
It's half true. There is no drain plug, the fluid must be sucked out through the fill plug, but GM recommends it be changed at 100,000 miles. It even says so in the owner's manual, IIRC. The best way to do it is to suck it out with a spray bottle top into the bottle it belongs to and throw that away, or use a syringe or similar, then fill using GM Supercharger Oil. It's a special formulation just for this application, and not anything like motor oil or any other fluid in the car. You can either get the oil from the dealer, in which case you'll need 2 of their 4oz bottles or you can get it from Intense Racing (www.intense-racing.com) or ZZP (www.zzperformance.com). They sell it in 8 oz bottles, and you'll need one of those.
Be aware that it smells to high heaven. It's made with whale blubber, and the stuff inside the S/C has been cooked, so it smells much worse...
PostPosted: Tue Jun 07, 2011 12:50 pm
Click the red link in my signature for more info.
I'll move your topic to the proper section. In addition, our Techinfo section has a wealth of information on this subject:
http://www.pontiacbonnevilleclub.com/fo ... m.php?f=56
PostPosted: Wed Jun 08, 2011 9:29 pm
Can this be mixed in with regular motor oil and taken in for recycling? If not, how do you dispose of it?
Ken_W
PostPosted: Wed Jun 08, 2011 10:37 pm
Use it as weed killer. And it's not whale blubber. It's animal fats, but very unlikely from whales.
If you want to mix it with your motor oil or trans fluid for recycling, do so. If you're wrong, I don't think they'll be knocking on your door to fine you for it.
There are no new unread posts for this topic. hot Supercharger
blackbeauty00
Thu Feb 10, 2011 11:27 am
willwren View the latest post
There are no new unread posts for this topic. supercharger
bobates
Mon Sep 06, 2010 9:47 am
There are no new unread posts for this topic. Supercharger Oil
wolfie3491
Mon Mar 07, 2011 1:45 pm
wolfie3491 View the latest post
There are no new unread posts for this topic. Supercharger oil
rynmcdonald
Thu Sep 19, 2013 7:43 pm
There are no new unread posts for this topic. 98 sse add a supercharger?
algore
Mon Nov 24, 2014 12:17 am
Users browsing this forum: Google [Bot] and 2 guests
