It is currently Sat May 25, 2019 9:36 pm
 Post subject: supercharger
PostPosted: Sun Sep 05, 2010 11:23 am
Year and Trim: 1992 bonneville ssei
I BOUGHT A 95 SUPERCHARGER AT THE WRECKING YARD YESTERDAY.. WILL IT FIT ON MY 92 SUPERCHAGED BONNEVILLE
 Post subject: Re: supercharger
PostPosted: Sun Sep 05, 2010 12:22 pm
No, it won't. You need one from a 91-93 Buick Park Avenue Ultra or a 92/93 Pontiac Bonneville only.
I'm not thinking this is an Audio question, so I'll move this to the proper section for you. In the future, please don't post all capital letters. That's viewed as yelling on Forums and other online venues.
PostPosted: Sun Sep 05, 2010 4:55 pm
It will fit, but won't be ideal without some more parts and some tuning. Your original throttle body will be mismatched (much smaller) than the 95 SC inlet. If you get the 95's throttle body to match, you'd want its MAF so it will even idle. Then you will need one or more of the following: adjustable fuel pressure regulator or a Series II regulator, bigger injectors, MAF translator, or a custom tune. And you must have a scan tool to make sure you've got it where it needs to be/tweak your fueling.
PostPosted: Sun Sep 05, 2010 7:57 pm
The bottom line is that there are only 2 cars running on the Forum this way, and one is mine and one is his ^^^^^^^.
Both of us have struggled with the setup. And I run a TON more than he mentioned. Fuel pressure alone is not enough to get it to run right. By the time you pay for all the parts you need to make it work, you'd have been better off buying a rebuilt PROPER supercharger for your car.
PostPosted: Sun Sep 05, 2010 8:56 pm
3...but I still agree with Bill
yourgrandma wrote:
High
PostPosted: Sun Sep 05, 2010 10:31 pm
Big difference, Wes. You haven't put out an effort to actually get it to run right.
Is it the right supercharger? No.
Can it be made to work? Depends.
Is it worth it? In most cases, no. Not even close.
PostPosted: Mon Sep 06, 2010 12:10 am
okay thanks... will the bearings from the 95 supercharger fit the 92 supercharger
PostPosted: Mon Sep 06, 2010 9:47 am
Do NOT use old bearings. Buy new ones. www.rollingperformance.com
Do you have a press or have access to one?
There are no new unread posts for this topic. hot Supercharger
blackbeauty00
Thu Feb 10, 2011 11:27 am
willwren View the latest post
There are no new unread posts for this topic. Supercharger Oil
wolfie3491
Mon Mar 07, 2011 1:45 pm
wolfie3491 View the latest post
There are no new unread posts for this topic. Supercharger oil
rynmcdonald
Thu Sep 19, 2013 7:43 pm
There are no new unread posts for this topic. 98 sse add a supercharger?
algore
Mon Nov 24, 2014 12:17 am
BestBonnieYet
Wed Jun 08, 2011 10:37 pm
