It is currently Wed Jan 23, 2019 5:04 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Post subject: ssei not boosting
PostPosted: Wed Aug 04, 2010 9:11 pm
Year and Trim: 1996 Pontiac Bonneville SSEI
i have a 1996 ssei and i took mt car to my mechanic because i was constantly having the p0171 enginlean code. i have my car back and now the rod from the bottom of the bca wont full extend, it only goes a quarter of the way. also i was wondering is there supposed to be vacuum coming from the sid of the bcs that goes to the bca. when i took the tube coming from the bcs to the bca off it started boosting is it the bca or the bcs. oh and i havent seen the p0171 in like 3 weeks but my boost guage is still jumping around any help with that would be greatly appreciated.
 Post subject: Re: ssei not boosting
PostPosted: Wed Aug 04, 2010 11:16 pm
Sounds like the BCS is bad. Normally, it allows atmospheric pressure to the bottom of the BCA, but when it fails, it only lets pressure from the LIM by to the BCA, keeping the lever up and the wastegate open.
PostPosted: Wed Aug 04, 2010 11:18 pm
Click the red text in my signature. Let us know what you find.
PostPosted: Thu Aug 05, 2010 6:36 am
that was enlightening, do you think you can send me a picture of how the vacuum routing is supposed to be all around the engine i think mine is wrong i dont have a t fitting undet the supercharger just 1 side connects to it
PostPosted: Thu Aug 05, 2010 9:12 am
The T fitting is in the lower intake manifold under the snout of the SC. Do you mean you don't have a vacuum line on it, or there is nothing there at all.
Your 96 is a little different because you have a vacuum port tree on the front of the SC, and 97+ doesn't, but this might help.
If you post a picture of your engine, I can draw how its supposed to be.
-Andrew-
PostPosted: Thu Aug 05, 2010 11:38 am
It has a line on it, the same lines come from my map sensors but it doesn't go to the fpr is that how it supposed to be. I have to be at work soon so i will post a pic us later today. I really appreciate the advice.
PostPosted: Fri Aug 06, 2010 10:21 am
[imgImage]ImageImage[/img]
will you be able to draw the lines out from these pics and i noticed my bcs is different i have to ends on it and when i unplugged the electrical connecter on it, vacuum started to come throught but when it is plugged up no vacuum comes throught at all. Also
PostPosted: Fri Aug 06, 2010 11:02 am
You are missing a vacuum line between the BCS and the BCA. Your BCA is also held together with a zip-tie, probably because it's broken/leaking.
These are the two current issues I see right now from your pictures.
PostPosted: Fri Aug 06, 2010 9:46 pm
i took the tube off of the bca and bcs to see if it would boost and it definately did, but sad thing about it is that i lost the tube have you get another one
PostPosted: Fri Aug 06, 2010 10:46 pm
Cut that tie-wrap off the BCA. If it falls apart, replace it. Harofreak00 probably has one or three laying around.
PostPosted: Sat Aug 07, 2010 12:06 am
it just wont stay to the housing.
PostPosted: Sat Aug 07, 2010 6:17 am
Year and Trim: 2002 Mazda Protege ES
Buy new tubing at any local auto parts store, replace it whether you think it needs it or not. Not the hard lines though, those should be good.
-Matt
PostPosted: Sat Aug 07, 2010 9:24 am
I see a vacuum boot coming out of the front of the throttle body flange with sealant stuff in it. You may have a leak there, too. At warm idle, what does your boost gauge read? Can you post a pic of it? That gauge can be a clear indicator of a vacuum leak. I also see other repaired vacuum lines on that motor.
As I see it, you have possible vacuum leaks, splices, a missing line, and a possible bad BCA for starters.
PostPosted: Mon Aug 09, 2010 4:49 am
the boost guage is sometimes steady on -7 and sometimes it jumps from -7 to -10 and when my car gets hot to where the fans cut on sometimes it is steady on -10 until i put my car in drive or even when i hit the brakes i see it jump. when i am goin like 50 mph its steady on - 10 until i slow down. I will post a pic later on today
PostPosted: Mon Aug 09, 2010 10:47 am
-7 is an indication of a pretty bad vacuum leak, or several small leaks. Please complete the repairs I've identified already in this topic (including replacing the BCS, adding a line from the BCS to the BCA, and repairing/replacing any improper vacuum line connections as pointed out), then when you're done with all that, please come back and tell us what symptoms remain.
PostPosted: Tue Aug 10, 2010 4:46 am
I will do that i appreciate the advice
PostPosted: Sat Aug 21, 2010 5:10 pm
Ok i was checking my car today and i noticed that my map sensors didnt have actual vacuum going to them could that cause a car to run lean. What i mean by not haveing vacuum is that the lines on the map sensors went from the map sensors to under the supercharger nose and stopped. where is that how it is supposed to be or is it supposed to go somewhere else after it goes under the nose of the supercharger.
PostPosted: Sun Aug 22, 2010 7:43 am
could this also be the reason for my boost guage jumping
PostPosted: Sun Aug 22, 2010 10:32 am
One of your MAP sensors is supposed to be connected to the fitting in the Lower Intake Manifold under the nosedrive of the supercharger. That's how it reads manifold vacuum or boost on the gauge.
Have you fixed all the vacuum lines and replaced your broken BCA like we suggested?
PostPosted: Sun Aug 22, 2010 3:30 pm
What you described about the Map sensors is exactly how it is. I just thought it was supposed to get some kind of vacuum from one of the other lines. I haven't been able to replace the bca yet but will do very soon.
There are no new unread posts for this topic. L36 or L67 Boosting
Murphy
Thu Jul 14, 2016 9:05 pm
95naSTA View the latest post
There are no new unread posts for this topic. Gen V on a 93 ssei?
ricosuave420
Thu Jan 18, 2018 8:33 pm
redfury View the latest post
There are no new unread posts for this topic. ssei ideas? in particular supercharger.
Sadden
Wed Apr 15, 2009 9:51 pm
Sadden View the latest post
There are no new unread posts for this topic. 2003 Bonneville SSEi
rynmcdonald
Tue Sep 24, 2013 6:59 pm
There are no new unread posts for this topic. 1993 ssei intercooler?
ricosuave420
14
1385
Sun Sep 10, 2017 4:06 pm
abudjak View the latest post
cron
