It is currently Tue Dec 10, 2024 5:22 am
 Post subject: some newbie SC questions
PostPosted: Sat Jul 17, 2010 9:00 pm
Year and Trim: 2000 SSEi w/ 99K
Ok so i had the rattling coming from the charger so i ordered the intense coupler kit. I got the old oil out *yuck* and took out all the bolts. Then i had to tap it with a mallet to get it to separate. Both of the sections separated (ie nosedrive to gears and the other side gears/rotors to case). I didnt think the coupler was that bad until i tried to push the new one on..the old one slid off into my fingers, and the new one i had to tap it with the back side of a screwdriver..its snug.
Questions before reassembly:
1.) Do both sides of what came apart need the anaerobic gasket maker? To be honest there did not look to be ANY residue of old gasket of any kind on that supercharger. I know that the nosedrive to gears needs it as there is oil in there but does the other side need it as it is only air in there?
2) Is it easier to put the coupler on the gears side or the nosedrive side for reassembly or does it not matter?
3) Do the bolts need the blue thread locker like all the other LIM bolts? I can find the torque specs in the FSM but wasnt sure about thread locker for this.
I appreciate all the info i can get..this is the first charger I have seen the guts of in person.
PostPosted: Sat Jul 17, 2010 11:09 pm
You can use the sealer for both sides. Don't use excessive amounts.
I can't see how it would matter which side you put the coupler on first.
You don't need thread locker on them.
PostPosted: Sun Jul 18, 2010 8:09 am
Thanks!
PostPosted: Mon Jul 19, 2010 7:31 pm
Thanks for the help..got her all back together today and its nice to be boosted again..and now its quiet boosted again. :banana:
PostPosted: Tue Jul 20, 2010 10:15 am
Perfect info for the nOoB:
http://www.3800supercharger.net/
PostPosted: Tue Jul 20, 2010 7:18 pm
Thanks Wren! I lurked that site for a while to make sure i felt up to the work. I am just glad that the coupler fixed the noise..i get to put off the bearing and needle bearing job for a while yet.
There are no new unread posts for this topic. some nitroussssss questions
TampaSSeI95
Mon Jul 07, 2008 1:30 pm
Allmachtige View the latest post
There are no new unread posts for this topic. Questions on either porting or gen V swap and C.A.R.B.
Ramcharger310
Mon Feb 14, 2022 1:07 am
Ramcharger310 View the latest post
There are no new unread posts for this topic. m90 supercharger oil change questions
ricosuave420
Fri Mar 08, 2013 10:03 pm
There are no new unread posts for this topic. A couple quik mod questions
spoiledred94
34
3980
Tue Sep 09, 2008 3:29 pm
dakotapalm View the latest post
This topic is locked, you cannot edit posts or make further replies. new supercharger questions! help please1
MADDEN95L
Thu Jul 29, 2010 7:57 pm
willwren View the latest post
