It is currently Sun Mar 29, 2020 9:00 pm
 Post subject: Help, recurring problem
PostPosted: Tue Feb 04, 2020 2:05 am
Hey all, I've searched the internet, but cant figure out how to fix this problem at all. So I'm turning to you all for some advice/guidance. 2002 Bonneville, keeps setting a P0336 code, crankshaft position sensor. It does this intermittently, and never when it's at my mechanics. I've replaced everything but the harmonic balancer, still does it. I'm totally lost here, can anyone give me a direction or idea where to go from here? Thanks in advance
PostPosted: Tue Feb 04, 2020 11:22 am
There are teeth on the back of the HB that the crank sensor reads. If there is damage there or its installed incorrectly you will have issues. You said you've replaced everything except the HB, so what have you all replaced? The CPS and....?
-Andrew-
PostPosted: Tue Feb 04, 2020 3:01 pm
Crank position sensor, cam position sensor, plugs, wires, coils, icm.....
PostPosted: Tue Feb 04, 2020 5:07 pm
If it does it intermittently, its probably a wiring issue. I would check for damage to that small harness that controls the ignition (Crank sensor, cam sensor, ICM)
-Andrew-
PostPosted: Wed Feb 05, 2020 12:22 am
If it's similar to an older 3800, the harness running down to the crank sensor is tucked into some nooks that tend to wear through the loom and insulation. Seen it a few times.
There are no new unread posts for this topic. No start due to electrical problem and/or security problem
SPLLOUDER
Wed Oct 17, 2012 8:53 am
sethjamesrimrodt View the latest post
There are no new unread posts for this topic. TPS problem
velvetdreams21
Thu Sep 11, 2008 9:34 pm
velvetdreams21 View the latest post
There are no new unread posts for this topic. There is such problem! 1995
vik3200
12
1965
Mon Feb 21, 2011 3:08 pm
Phantom View the latest post
There are no new unread posts for this topic. Window Problem
MikeGM24
Thu Sep 27, 2012 7:09 pm
There are no new unread posts for this topic. really weird problem
SLEking
Mon Jul 19, 2010 1:33 pm
SLEking View the latest post
