It is currently Wed Jan 22, 2020 4:24 am
PostPosted: Sat Oct 19, 2019 10:03 pm
Year and Trim: 1997 SSE
Grandson was cycling brightness and vertical position of 97 Bonneville SSE heads up display when display disappeared, so hopefully my issue is simply to replace the fuse. But i haven’t found any documentation of location of fuse for HUD. Need to know if location is under dash or under hood and how to identify it.
THANKS FOR ANY HELP LOCATING THE EXACT FUSE LOCATION!
PostPosted: Sun Oct 20, 2019 7:32 pm
hi, if you lower the hud too much, it goes off screen - adjust it higher slowly and you will see it
make sure hud brightness is on max - do it at night
here is your manual..........https://my.gm.com/content/dam/gmownerce ... owners.pdf
There are no new unread posts for this topic. 91 Bonneville SSE A/C fuse keeps blowing
Scripttester2
Sun Mar 29, 2015 6:22 am
rustyroger View the latest post
There are no new unread posts for this topic. 1998 Bonneville Fuse Box Dead
chuck202003
Mon Aug 22, 2011 1:53 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 2003 pontiac bonneville se fuse box and relay problems! help
tom4221
Wed Sep 29, 2010 11:29 am
There are no new unread posts for this topic. Rear Fuse Box (finding a certain fuse)
JoeK
Thu Apr 26, 2012 9:17 pm
JoeK View the latest post
There are no new unread posts for this topic. 1997 Bonneville SE- ground bus issue
edarr
Fri Dec 06, 2013 10:11 pm
