It is currently Mon Feb 24, 2020 3:14 pm
PostPosted: Tue Jun 04, 2019 7:02 pm
Year and Trim: 2005 Pontiac Bonnevile SE
Currently my cigarette lighter fuses (22 AUX PWR, and 23 C/LTR) are set to the outer positions and are powered constantly. Moving the fuses to the inner position to switch power off on key off causes the ports to not receive power at all. Regardless of either fuse position, the raido turns off on key off(10 mins after). What would be my next step in figuring out how to fix this?
PostPosted: Wed Jun 05, 2019 9:29 am
I would next suggest you probe the fuse ports with a multi-meter to find the position that works.
I blew the fuse and now it wont work so,I will be doing the same by the weekend.
I may just put 2 fuses in to see what happens.
PostPosted: Wed Jun 05, 2019 10:13 pm
In the outer positions the cigarette lighter receives power. In the inner positions they do not. In this image they are in the outer positions. Image
PostPosted: Thu Jun 06, 2019 4:14 pm
Did you check for voltage across the inner fuse sockets and batt-?
PostPosted: Thu Jun 06, 2019 8:24 pm
ok, the radio is supposed to turn off at 10 min after key off. this is how it works in my 2000 and I have confirmed that your 2005 works the same
https://my.gm.com/content/dam/gmownerce ... owners.pdf
2-24
There are no new unread posts for this topic. Cigarette lighter problems in 01 Bonneville
Rep K
Sat Jul 06, 2013 12:30 am
Archon View the latest post
There are no new unread posts for this topic. My cigarette lighter stopped working
seekinhighhp
Sat Nov 24, 2012 5:19 pm
seekinhighhp View the latest post
There are no new unread posts for this topic. Cigarette Lighter working intermittently?
Mary
Wed May 11, 2011 6:39 pm
leatherneck View the latest post
There are no new unread posts for this topic. 93 cigarette lighter socket came apart,what to do! glovebox
Azzy
Fri Aug 31, 2012 9:29 am
TDS-94SSEi View the latest post
There are no new unread posts for this topic. REAR cigarette lighter in 1993 SSEi
across777
Fri Jul 12, 2013 3:22 pm
across777 View the latest post
