It is currently Wed Nov 20, 2019 11:40 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Tue Jun 12, 2018 1:16 am
Year and Trim: 2005 Pontiac Bonneville 3.8 SE
Does the sensor in the middle of my dash board have to do with the a/c temperature or lights? (2005) pontiac bonneville 3.8)
PostPosted: Tue Jun 12, 2018 8:49 am
Yes sir, if you have automatic climate control in your SE, the sensor controls the air temp depending on the angle of the sun. It also tells the car when to turn the lights on.
"Penelope" - 2003 SLE - 193k Miles
"Sydney" - 2000 Honda S2000 - 67k miles
PostPosted: Tue Jun 12, 2018 11:19 pm
I forgot to mention it has no automatic climate control! Sorry. My a/c was working fine then one day it just seem to be a little warmer than usual. I had a new a/c compressor in my storage so I thought I might as well use it. I changed the orfice tube, checked for leaks. Can't find the problem. Low side is about 43 and I think the high side was compatible at 210 or in that area. Friend said it all looked ok. Don't know what to do! help!
PostPosted: Tue Jun 12, 2018 11:40 pm
I can't speak to the A/C problem other than does the condenser look plugged with bugs or otherwise occluded? In response to your other question, in a non-dual climate control vehicle such as yours, that is only an ambient light sensor. It will have no effect on your problem.
PostPosted: Wed Jun 13, 2018 1:19 am
You should probably put eyes on your airmix actuator to make sure it is functioning properly.
PostPosted: Wed Jun 13, 2018 11:44 pm
There is not rubbish such as leaves or obstructions on my condenser and no leaks. I'm wondering if I should just vac and refill coolant and oil.
PostPosted: Sun Jun 17, 2018 1:51 am
2004 Bonneville GXP
check your cabin air filter to make sure it is not clogged up with leaves and debris and change it if you have never done so.
bobgto65
PostPosted: Sun Jun 17, 2018 3:27 pm
Good thought, but probably doesn't have a filter. I don't recall which year GM stopped installing these, but well before the 2005 model year. Also, I'm not sure if the SE ever got them unless the owner added it after the fact. My GXP didn't come with one. That was one of the first GM cheap-outs I corrected!
PostPosted: Sun Jun 17, 2018 9:44 pm
:withstupid:
PostPosted: Mon Jun 18, 2018 9:59 pm
I feel so stupid, but here it goes. I don't even know if my pontiac has automatic climate control! I don't think it does based on the different a/c face and knobs. I know there are 2 small a/c vents at the end of the counsole for the back seat. There is an air filter for the A/C after removing a compartment door located near the windshield under the hood on the passenger side and it's like new. Aluminum fittings on the accumulator hose going to the firewall (evaporator) is cold, but inside temp barely cool. No leaks in system. Has a new accumulator, compressor and orfice tube. Only thing I can think of is the condenser and evaporator. I have no diagram on how to change the evaporator core, but I know it's under the dash.
PostPosted: Mon Jun 18, 2018 11:40 pm
Check to see if you can change the controls to heat the interior. If you don't get heat, then the head unit for the HVAC may be faulty. I'm dealing with no heat/cooling control on the drivers side presently. I'm going to have to pull the kick panels off and look at the actuators to see if they are moving in conjunction with the controls. It could very possibly be the blend door actuator if you cannot command heat either.
Your low and high side numbers are fine, so the A/C is working, you just aren't getting conditioned air directed into the cabin without being blended with heat.
PostPosted: Tue Jun 19, 2018 12:12 am
I checked the actuator under the glove box. I benched tested it and it works, but when I plugged it in before reinstalling, none of the buttons on the a/c panel moved the actuator. Now I'm thinking it's my a/c controls. I got the coldness back by resetting the flap manually and did not plug the actuator in after reinstalling it. The heater doesn't work and did not work throughout my testing. That's ok with me cause I don't use the heater, but I still would like to correct this. Would you think it might be the a/c control panel?
PostPosted: Wed Jul 25, 2018 8:49 pm
Year and Trim: 2003 Pontiac Bonneville SLE - Silver
For the 2000 SSEI I just picked up, it seems the sensor is either unplugged or faulty as the lights are on even on a sunny day like today. I tried to control this by shutting off the delay for headlights, while in park. While it worked, once I put the vehicle into gear the headlights came right on....
2012 Honda Odyssey | Drk. Cherry | Family Car
2003 Bonneville SLE | Silver| 136k | Daily Driver
2000 Bonneville SSEI | Black| 122k | Wife’s
1994 Chevy Caprice LT1 | White | Summer Toy
Former:
1997 Bonneville SE | Black |127k| Sold
PostPosted: Thu Jul 26, 2018 12:20 am
Make sure your wiper lever is in the off position. If it is inadvertently on, all the exterior lights will come on after six seconds.
PostPosted: Thu Jul 26, 2018 9:04 am
yes, check to see if the air blend is working well, I get ac from pass but not driver - ac works great - air blend is stuck on outside air
check that first - may save you hours of wasted diagnosis on the system
PostPosted: Thu Jul 26, 2018 10:14 am
Wipers are off and not moving at all. It's odd, I will do some more investigating today seeing if something is actually obstructed the sensor as well. Are these known to do this?
Former:
PostPosted: Sun Jul 29, 2018 1:30 pm
There have been the occasional reports of these sensors failing, but few and far between. As for the wipers, GM believes that if they are on for more that six seconds, a poor visibility condition may exist and the vehicle automatically turns on your park and headlights. This operation is by design.
When you say your lights come on when you take the vehicle out of park, do you mean just the headlights (during the day), or all the marker/park lights as well?
PostPosted: Mon Jul 30, 2018 6:58 pm
It's all of them, and the actual headlights come on as well, not the DRL. It is baffling because the twilight sentinel is in the off position and as soon as you start the car the lights all come on as well. If I adjust the twilight sentinel and turn it on and then off it is the only way it stays off, but again as soon as it is shifted out of park, everything comes on.
Former:
PostPosted: Mon Mar 11, 2019 8:41 pm
So after 7+ months, I still cannot drive the vehicle in daylight (sunny days) without the headlights coming on completley with parking lights/tail lights on as well and staying on. The auto temp sensor works perfectly fine with whatever temp I set it to. I have even shined a bright light onto the Sensor that is on top of the dash. I have a few questions as I'm a little confused to as what the sensor* on the top of the dash does exactly. (*I recently bought part AC DELCO #12160947 based on what I thought/think is the sensor to fix this problem)
1) the above part #, if I swap this out, from my understanding in this current thread, it should regulate the cabin temperature and decide when to turn on the headlights (if twilight sentinel is on, and is obviously dark out);
2) what is the procedure to swap out the above sensor as I feel pulling upwards on it will break it.
Thanks!
Former:
PostPosted: Tue Mar 12, 2019 6:30 am
It's not the sole component used to regulate cabin temperature but works in conjunction with thermistors (temp sensors) in several of the ducts. Cadmium sulfide photo cells under the dome determine the level of light shining onto the vehicle. Ultimately, it controls whether the daytime running lights illuminate or headlights at full intensity and the tail lights. The brighter the sun shining onto the occupants, the warmer it will feel and the more the cabin temperature will drop to compensate (as opposed to straight air temperature).
The defrost grille snaps into the dash pad. To change the part, you must pop this piece out of the dash pad. A non-marring trim tool is usually the recommended item, but a slot screwdriver will get under the edge as well. You will increase the possibility of damaging either the grille or pad though with anything that has sharp edges. The sensor twists about 1/4 turn into the grille and is removed from the underside.
There are no new unread posts for this topic. Outside temperature sensor
91NinetyEight
Thu Aug 18, 2011 9:43 pm
willwren View the latest post
This topic is locked, you cannot edit posts or make further replies. ambiant temperature sensor
2005 pontiac
Tue Jun 05, 2018 2:53 am
ddalder View the latest post
There are no new unread posts for this topic. Air temperature door
HATNINJA
Tue Oct 22, 2013 12:39 pm
There are no new unread posts for this topic. Radiator Cooling Fan Temperature Contol Switch
Mooch60122
Wed May 25, 2011 10:53 am
There are no new unread posts for this topic. Electronic dash goes off and on...
suedoug88
Wed Mar 24, 2010 2:30 am
sepenator View the latest post
