It is currently Sun Aug 25, 2019 2:31 pm
PostPosted: Wed May 16, 2018 1:11 pm
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
We purchased a 2000 Impala LS (3800) and there was not a keyless remote from the seller.... So we got several remotes, and tried to synch them by using the prompts on the factory radio.....could not get the remotes to synch.....then used a GM Tech II tool and still could not get them to synch..... we've tried both remotes since it appears there are 2 remote numbers for these cars..... is there anything else we can try.... if we can't get it, is there a possibility the Wireless Entry Module is bad? Where is that located on the 2000 LS, how would you check it for it being bad..... if we got another from a junk yard, is there a procedure to hook it up?
PostPosted: Wed May 16, 2018 3:08 pm
The module is located behind the rear seat in the trunk up by the 6x9 speaker. It should be gray and about 2"x3". It should say FCC ID:KOBUT1BT on it, as should your remotes. If the remotes are KOBLEAR they will not work. If your Impala is a real base model, it might not even have keyless from the factory. The modules are plug and play, no programming required.
-Andrew-
PostPosted: Wed May 16, 2018 3:35 pm
The part number on your remote control should be 25678792 (25668603 was the previous part number). You may want to confirm this. The factory parts list shows this remote is for the following vehicles:
Buick Lesabre 4DR CUSTOM 1996, 1997, 1998, 1999
Buick Lesabre 4DR LIMITED 1996, 1997, 1998, 1999
Buick Park Avenue 4DR Base 1996, 1997, 1998
Buick Park Avenue 4DR ULTRA 1996, 1997, 1998
Buick Riviera 2DR Base 1996, 1997, 1998, 1999
Chevrolet Impala 4DR Base 2000
Chevrolet Impala 4DR LS 2000
Chevrolet Malibu 4DR LS 2000
Chevrolet Malibu 4DR LX 2000
Chevrolet Monte Carlo Base 2000
Chevrolet Monte Carlo LS 2000
Chevrolet Monte Carlo SS 2000
Oldsmobile 88 4DR 50TH ANNIVERSARY 1999
Oldsmobile 88 4DR Base 1996, 1997, 1998, 1999
Oldsmobile 88 4DR Regency 1997, 1998
Oldsmobile 88 4DR REGENCY 50TH ANNIVERSARY 1999
Oldsmobile 88 4DR Royale 1996, 1997, 1998, 1999
Oldsmobile 88 4DR ROYALE LSS 1996, 1997, 1998, 1999
Oldsmobile 88 4DR ROYALE SERIES 1996, 1997, 1998, 1999
Oldsmobile 98 4DR Base 1996
Oldsmobile Alero 2DR GL 1999, 2000
Oldsmobile Alero 2DR GLS 1999, 2000
Oldsmobile Alero 4DR GL 1999, 2000
Oldsmobile Alero 4DR GL SED 1999, 2000
Oldsmobile Alero 4DR GLS 1999, 2000
Oldsmobile Aurora 4DR Base 1996, 1997, 1998, 1999
Pontiac Bonneville 4DR SE 1996, 1997, 1998, 1999
Pontiac Bonneville 4DR SSE 1996, 1997, 1998, 1999
Pontiac Grand Am 2DR GT 1999, 2000
Pontiac Grand Am 2DR GT1 2000
Pontiac Grand Am 2DR SE 1999, 2000
Pontiac Grand Am 2DR SE1 2000
Pontiac Grand Am 2DR SE2 2000
Pontiac Grand Am 4DR GT 1999, 2000
Pontiac Grand Am 4DR GT1 2000
Pontiac Grand Am 4DR SE 1999, 2000
Pontiac Grand Am 4DR SE1 2000
Pontiac Grand Am 4DR SE2 2000
PostPosted: Thu May 17, 2018 1:03 am
stand in front of car - press both lock and unlock at the same time
the alarm should cycle horn and lights - see if it works after that.
There are no new unread posts for this topic. cant get remote lock/unlock fob to program
Jbro238
Wed Aug 13, 2014 10:42 am
Jbro238 View the latest post
There are no new unread posts for this topic. 2000 SSEi keyless remote programing
garys615
Thu Sep 17, 2009 9:52 am
garys615 View the latest post
There are no new unread posts for this topic. Best remote start you can buy?
terrancew3
Sat Feb 08, 2014 10:45 pm
There are no new unread posts for this topic. Keyless Remote Entry
gray8160
Thu Jan 20, 2011 6:35 pm
There are no new unread posts for this topic. Keyless Remote Issues....
Blown93SSEi
Tue Dec 23, 2008 5:55 am
Blown93SSEi View the latest post
