It is currently Sun Jan 20, 2019 1:36 am
 Post subject: Tail Light
PostPosted: Fri Mar 16, 2018 9:09 pm
My right rear tail lights are out on my 03 bonneville. The brake lights work, as does the turn signal, and back up light, first I thought it was the bulbs but it's not. With a test light there is no power coming to the connection of the running lights that's in the trunk. Is there a relay that is just for the tail lights?
 Post subject: Re: Tail Light
PostPosted: Fri Mar 16, 2018 9:19 pm
there is a fuse under back seat - brake lights
PostPosted: Fri Mar 16, 2018 9:24 pm
my brake lights work though, just tail lights do not
PostPosted: Fri Mar 16, 2018 11:47 pm
ok, park lamp fuse - same place
PostPosted: Sat Mar 17, 2018 9:23 am
ok, I'll check that out
PostPosted: Sat Mar 17, 2018 11:38 am
had a blown fuse, replaced it and now have power to the connection in the trunk but, still no lights on, maybe bad light sockets or the bulbs are bad again. Its strange both would have went out at the same time but, it does get wet in there since the fixtures lost there sealing capabilities. Wish new ones were available
PostPosted: Sat Mar 17, 2018 1:09 pm
Fixed, blown fuse must be due to the water, new bulbs and drilled holes to let the water drain
There are no new unread posts for this topic. Tail Light/Brake Light/Turn signal light question
1oldman
Fri Sep 23, 2016 9:21 pm
There are no new unread posts for this topic. tail light socket
windshield_time
Thu Jan 15, 2009 11:24 pm
There are no new unread posts for this topic. Center tail light up
xrob
Wed Jun 06, 2012 11:48 am
Archon View the latest post
There are no new unread posts for this topic. Tail light socket replacement help!!!
ncast139
Fri Mar 09, 2012 10:30 pm
There are no new unread posts for this topic. 1993 ssei tail light sensor
ricosuave420
Fri Mar 01, 2013 12:26 pm
ricosuave420 View the latest post
