It is currently Fri Apr 26, 2019 6:01 am
PostPosted: Mon Aug 21, 2017 12:15 pm
Year and Trim: 2003 SSEI
Okay so if this has been discussed direct me to where I need to go please. So I have found the infamous water on the floor and have since repaired the splices and found the drains for the sunroof were off and draining in the car. Now I lost the passenger side brake lights with no power to the plug on the harness in the trunk. Both the driver and the third brake light work fine. I did add a jumper from the driver side to keep the car on the road but would like to fix them properly. Friday night the dash lights worked, did the splice repair on Saturday and now I don't have the back lighting on the cluster, no button lights on the radio or the heater control, but the displays work on all of them. ON the cluster the DIC works, all gauges work the PRND light up MPH lights up, bright indicator but no back lighting at all. Checked fuses but didn't seem to find one bad. One odd thing and I would guess it to be the rheostat, I tried the dimmer knob up and down, it turns on the interior lights but yesterday wasn't dimming the lights on the cluster that do light, but today it is. If it is the rheostat then where can I source one?
PostPosted: Mon Aug 21, 2017 10:07 pm
Double check the fuses in the rear fuse block for that interior illumination issue. I believe it is #14 or #38.
Andrew over at Bonnevilles Unlimited can get you almost any part you need for these cars. His screen name on the forum is Harofreak00.
PostPosted: Wed Aug 23, 2017 8:43 pm
So just triple checked the fuses and even swapped them out for new ines and no change thank you for the reply.
PostPosted: Thu Aug 24, 2017 2:58 pm
Alright, in that case, you will likely need a new dash integration module in order to restore your interior gauge and control lighting. A resistor goes bad inside on very rare occasions.
There are no new unread posts for this topic. 2000 ssei - brake lights work but not tail lights
mbrand2
Thu Feb 21, 2013 12:37 am
Archon View the latest post
There are no new unread posts for this topic. 1993 SSEI no lights
krugsss07
Tue Mar 01, 2011 2:05 pm
krugsss07 View the latest post
There are no new unread posts for this topic. Attachment(s) 98 ssei fog lights are staying on all the time .
cheese
Sun Oct 16, 2011 10:38 am
There are no new unread posts for this topic. 95 SSEi dash lights including DIC
skregal
Sun Mar 13, 2016 9:45 am
skregal View the latest post
There are no new unread posts for this topic. 97 ssei gauge cluster lights and needles not working
jordanelrod
Mon Apr 27, 2015 8:25 pm
haro1225 View the latest post
