It is currently Fri Feb 23, 2018 10:26 am
PostPosted: Mon Jun 05, 2017 9:35 am
Year and Trim: 2001 Pontiac Bonneville SLE
Hey everybody, I'm new to the Bonneville scene. I just picked up an 01 SLE. There is barely any air that comes out of the driver side vents. They are open, but nothing but a trickle comes out. The AC blows cold and strong on the passenger side. I've had a lot of other electrical issues that I've fixed in this car, so could this be electrical as well, or a blockage in the air ducts? Any help is appreciated.
PostPosted: Mon Jun 05, 2017 10:22 am
1993 Bonneville SSE
Do you have air coming out of the floor vent or windshield vent on the drivers side or nothing at all?
'93 SSE "Guinevere" Mods: Intense FWI | 180º T-Stat | Flowmaster 80 | Magnaflow Cat | Projector Fogs | Clear Corners | ES Poly End Links
Achievements: Guinevere - 264k mi | 16.27 @ 84.10mph | March '11 COTM :: Chloe - 223k mi | 13.85 @ 102mph | January '09 COTM
PostPosted: Mon Jun 05, 2017 10:50 am
There is nothing at all coming from the driver side. I'll look when I get home to see if any blows out when I switch to defrost or floor, but I don't believe it did. But it switches fine on the passenger side.
PostPosted: Mon Jun 05, 2017 2:24 pm
1993 Bonneville SSE
It's a somewhat common problem for one of the actuators to fail. If you do still have have air flow on the drivers side but can't change where it comes out then the actuator would be the issue. One on each side controls the airmix and there's one on each side that controls airflow direction.
PostPosted: Mon Jun 05, 2017 6:32 pm
When I switch the vents over, the tiny trickle of air switches with it. It just doesn't blow out hard. It's almost as much air that comes out with the blower motor off.
There are no new unread posts for this topic. All driver's door electronics work EXCEPT driver's window
bradleymc
Tue Apr 29, 2014 9:08 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Driver window controls and driver A/C
forevercasual
Mon Jul 23, 2012 5:43 pm
There are no new unread posts for this topic. Nothing coming through vents
sjonesd3
Thu Feb 13, 2014 4:51 am
sjonesd3 View the latest post
There are no new unread posts for this topic. 1997 Bonneville SE - no air from front vents.
clgtk2
Sun Feb 23, 2014 7:11 pm
clgtk2 View the latest post
There are no new unread posts for this topic. driver side foglight
93bonnevillese
Thu Sep 01, 2011 4:50 pm
93bonnevillese View the latest post
