It is currently Fri Jan 18, 2019 6:44 pm
PostPosted: Sun May 14, 2017 2:38 pm
Year and Trim: 2002 Bonneville V6 K engine
I can only find two fuse/relay boxes. One under rear seat and one under front right hood. Neither has the blower motor relay listed. Any suggestions where else to look? Do not have a right and/or left under hood fuse box near firewall as mentioned in other threads. Blower motor stops and then starts again intermittently. When it runs all speeds work so resistor should be OK. Blower is good. My guess is a relay or loose wire.
PostPosted: Sun May 14, 2017 8:08 pm
The blower is controlled by the blower control module. It is attached to the right side of the blower housing. However, an intermittent blower is most often caused by worn brushes or commutator on the blower motor. If beating on the dash, or the blower starts it, that would pretty much confirm it.
There are no new unread posts for this topic. Blower Motor Relay
Sgt Wonderful
Mon Aug 18, 2014 12:34 pm
Sgt Wonderful View the latest post
There are no new unread posts for this topic. 2002 SSEI blower motor not working after replacing battery
WoodyBalto
Wed Oct 17, 2018 6:23 pm
WoodyBalto View the latest post
There are no new unread posts for this topic. Need diagram for heater blower relay
siddair
Mon Mar 11, 2013 5:56 am
siddair View the latest post
There are no new unread posts for this topic. high speed blower relay burning out
'99Bonnie
Thu Jun 28, 2018 10:16 pm
'99Bonnie View the latest post
There are no new unread posts for this topic. blower motor
bonnie33
Wed Feb 06, 2013 8:21 pm
