It is currently Tue Jan 22, 2019 4:37 am
 Post subject: Pulley, Alternator
PostPosted: Wed Apr 26, 2017 7:33 pm
Year and Trim: 94 SE
Last July I replaced my wore out alt with a high amp one. (replaced the belt too) The new one came with a smaller (overdrive? pulley) and meassures just under 2". Not had any issues until recently ( mainly because of rain & puddles here in southern MO) the belt slips to point the my volts will drop down to about 8-10v until the pulley & belt dry off. Can be several seconds.
Anybody know a part number to a shorter length belt from another vehicle that may fit? I believe I still have my old alt around that I can scab the oem size pulley to replace the smaller one if I need to. The instruction info with my new alt said to leave the smaller one on it tho...
NKS
 Post subject: Re: Pulley, Alternator
PostPosted: Wed Apr 26, 2017 10:07 pm
Most belt manufactures use a part number that designates how many ribs and how long it is.
A 94 SE serpentine belt is a 6 rib and somewhere between 102.5" and 103" long.
So take DAYCO for example, p/n 5061025DR. The 6 is for 6 rib, the 1025 is for 102.5" long. To get a 0.5" smaller belt, see if p/n 5061020DR exists. Or take any other p/n and replace 1025 with 1020.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Thu Apr 27, 2017 10:13 pm
While looking at belts I had that idea on the size but wasnt certain if it was or not. Thanks much!
PostPosted: Fri Apr 28, 2017 8:14 am
I would install a splash shield and keep water out of the engine bay - that should solve your issue.
There are no new unread posts for this topic. ho alternator
J. Baker
Wed Jul 29, 2009 3:39 am
Bugsi View the latest post
There are no new unread posts for this topic. alternator
SHEFFI81
Tue Jun 28, 2011 11:07 am
There are no new unread posts for this topic. New Alternator?
OnlyAnSE
Tue Sep 09, 2014 11:42 pm
bobgto65 View the latest post
There are no new unread posts for this topic. S.F.L.P. (Alternator Connector)
trigga_b
Thu Aug 28, 2008 10:54 am
trigga_b View the latest post
There are no new unread posts for this topic. Rebuilding an Alternator
Alibi
Tue Oct 28, 2008 10:35 am
Alibi View the latest post
