It is currently Thu Feb 21, 2019 1:53 pm
PostPosted: Tue Mar 21, 2017 1:27 am
Year and Trim: 1999 SSEI
hey guys,,,,i keep hearing about how is possible to change this actuator motor from under the dash on the pass side. I pulled the pass seat, bottom panel, inner glove box(no help due to the bar). I layed and looked under the dash for 30 mins and can barely get my pinky finger up there, let alone my hand. I tried to look at stuff to remove to get closer to it but that seemed fruitless. I`ve seen many guys say it is possible but never any links or direction on how to do so,,,,,,,any help is appreciated......
PostPosted: Tue Mar 21, 2017 12:21 pm
Year and Trim: 96 SE
I feel your pain. but it is possible. I have extra grande hands so I fashioned small wrenches or sockets onto extended socket wrench handle. it was laborious but can be done. you might have to use your imagination to fashion a tool that would fit your circumstances.
PostPosted: Tue Mar 21, 2017 1:48 pm
I can't even see a path to get to get a tool up there from under the dash.
PostPosted: Tue Mar 21, 2017 1:53 pm
If I just had a starting point,,,,,where do I attempt to go in? Along the firewall or through the middle???? What else can I remove first? If anything?
PostPosted: Tue Mar 21, 2017 5:41 pm
1992/topic36554.html?hilit=AIRMIX ACTUATOR BLEND DOOR REPAIR#p350630
there are lots of links in the forum to other experiences. see above link. to find more go to the search function and type AIRMIX ACTUATOR. the search function can get you started as to others experiences. report your experience and maybe others can give more info. I know it sounds impossible but one member changed the unit in 1/2 hour. but to be more realistic, probably more like 4 hours (my time). as stated, I was fabricating makeshift tools to make the job easier.
also try this link.
1992/topic32500.html?hilit=bonneville airmix actuator#p322835
PostPosted: Wed Mar 22, 2017 1:32 am
thank you much GMAN!
PostPosted: Thu Mar 23, 2017 1:37 am
gmman wrote:
http://www.pontiacbonnevilleclub.com/forum/1992/topic36554.html?hilit=AIRMIX ACTUATOR BLEND DOOR REPAIR#p350630
also try this link.
GMAN,,,,,,, thank you so much for the links again. I was able to get the actuator motor out with the excellent instructions in that link to trialnutz. If I could find him, I would thank him personally. And indeed it was the big white gear that was cracked,(along with 2 or 3 smaller cracks near the hub) throwing off the timing within the motor and faulting the ECC to flash. I`m just perplexed with GM and wonder why a safeguard was not built into the system if this is indeed caused by battery disconnects. Or was it a possible run of defective gears in the processing line? :dontknow: Either way, GM did make it a mother to get to and the dealer remedy is pulling that dash,,,,about 6-8 hours of book time just for the R&R of the dash. That is a huge labor tab for a 60$ AC Delco part. :eek2:
PostPosted: Mon Mar 27, 2017 9:34 am
Year and Trim: 2003 SSEi
You're welcome. :mrgreen:
I'm not sure the battery disconnect actually causes the problem, just exacerbates an existing one.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
There are no new unread posts for this topic. 2002 SSEI window door lock Question
flopo
Sun Aug 19, 2012 6:43 pm
flopo View the latest post
There are no new unread posts for this topic. Power Door Locks 1995 SSEI RESOLVED
Dustin
Fri Apr 06, 2012 11:06 pm
Dustin View the latest post
There are no new unread posts for this topic. Air mix actuator???
BlaikM
Fri Oct 14, 2016 5:13 pm
BlaikM View the latest post
There are no new unread posts for this topic. driver's door controls.... window, seat memory and door lock
justoyz2
Thu Oct 17, 2013 1:43 am
justoyz2 View the latest post
There are no new unread posts for this topic. Attachment(s) 03 SSEi drivers door electrical issues - all issues fixed
crash93ssei
27
4973
Sat Apr 12, 2014 3:22 pm
Oldman View the latest post
Users browsing this forum: Google [Bot] and 2 guests
cron
