It is currently Thu May 28, 2020 5:49 pm
PostPosted: Mon Aug 25, 2008 12:34 pm
Year and Trim: 1993 SSEi, Red Bonnechetta
2003 GMC Envoy SLT
Hi there,
I'm wondering how tough it is to R&R the turn signal switch? I'm looking at another 1993SSEi and the turn signal lever just flops around, obviously broken somewhere. Do I need to remove the steering wheel to fix it, or can I get to it via that little cover that comes off at the side of the steering column??
Thanks,
Adam
1993 SSEi "Red Bonnechetta" COTM July 2014
2003 GMC Envoy SLT
Last edited by labonnevillastrangiato on Sat Aug 30, 2008 9:25 am, edited 1 time in total.
PostPosted: Mon Aug 25, 2008 1:03 pm
I cheated when I did mine. I replaced the whole column :P
BonneMe wrote:
PostPosted: Mon Aug 25, 2008 1:08 pm
You need to remove the steering wheel and the lock plate.
viewtopic.php?f=19&t=4294
-Andrew-
PostPosted: Sat Aug 30, 2008 9:26 am
2003 GMC Envoy SLT
Alrighty,
Got some pics of the problem.
The bracket that holds the switch in is broken:
A pin passes from the top of this broken piece, through the hole in the multi-function switch, then connects to the bottom bracket. The bottom bracket actuates the left / right turn function. (If I push down / lift up on the bottom bracket, it activates the signals)
Is there an easy way to fix this? It seems as though the switches are fine, its the bracket that is giving the trouble.
Will everything have to be taken apart to get to this piece? Can it be JB Welded?
Thanks,
Adam
2003 GMC Envoy SLT
PostPosted: Mon Sep 08, 2008 2:12 pm
You can always try JB weld but I don't know how well it would hold. The only way to replace the switch outright would be to tear the column down far enough to get the plastic collar off the shaft so that you can slide the wire harness up the inside of the column and then out. Its a PITA to do which makes swapping the entire column easier... just save the old column for spares though (its got other switches and goodies on it that are good to have around).
-Eric
-1987 Fiero GT: 224k miles
There are no new unread posts for this topic. Where Is The Turn Signal Flasher At?
Blown93SSEi
Thu Sep 20, 2012 12:58 pm
Mad Myche View the latest post
There are no new unread posts for this topic. Turn signal problem
theax40
Tue Jun 19, 2012 8:51 pm
theax40 View the latest post
There are no new unread posts for this topic. Turn signal gremlins (02 SSEi)
1994se
Sat Apr 30, 2011 2:53 am
There are no new unread posts for this topic. Right front parking/turn signal.
gold_xero
Fri Aug 03, 2012 10:43 am
gold_xero View the latest post
There are no new unread posts for this topic. Turn signal wiring and battery draw?
squeaksmith
Fri Dec 20, 2019 1:40 am
ddalder View the latest post
