It is currently Tue Apr 16, 2024 12:58 am
PostPosted: Tue Aug 11, 2015 2:11 pm
Year and Trim: 2004 GTO
This is on the 04 GTP. Lately I've noticed the voltage has been reading lower than normal. I bought a ZZP voltage booster, which helped but not as much as I'd like. Today I saw 12.4 while the engine was running. I tested the system a couple weeks ago and it said dead battery, so I replaced it under warranty. I tested it again today and everything passed.
I noticed something when I tested it today. The test machine has a volt meter and it shows 14.6 but the DIC and scangauge say 13.3. As of Sunday another problem came up but I'm not sure if it's related. ABS and traction lights come on very briefly and go back off just as fast, sometimes before the DIC gives the service message. I scanned it and it gave me a U1016 code. Loss of communication with the power train control module. No check engine light though.
Does this sound like a wiring issue somewhere, or maybe a sign of a failing PCM or alternator? Otherwise the car works normally, and the alternator tests good every time.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:
Hi.
PostPosted: Tue Aug 11, 2015 4:32 pm
Check all your fuses. A dash integration module fuse was popped in my car and made my voltage gauge inoperable.
"Penelope" - 2003 SLE - 247k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Tue Aug 11, 2015 4:46 pm
I plan on it, I'm going to take the fuse box apart and make sure all the connectors are clean too. There is no gauge though, it's just a digital readout on the DIC.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Tue Aug 11, 2015 6:07 pm
All fuses are good, I might just have to refresh the cables.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Fri Aug 14, 2015 8:45 pm
Today I got the brief ABS warning again, and along with it all the gauges quit working except the speed. On the DIC it says ERROR MI so now I have no way to see how much fuel I have.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Tue Aug 18, 2015 9:09 pm
Dash/instrument panel integration module(s)? Not sure how similar those 04+ w-bodies are to 2000+ Bonnevilles, but those come to mind.
PostPosted: Tue Aug 18, 2015 9:19 pm
It hasn't happened again till just now. It seems like it has to do with the OBD2 connector. I unplugged the scangauge and they came back. Didn't happen again once I plugged it back in.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Aug 19, 2015 7:38 am
Year and Trim: 2003 SSEi.
LOTS of Mods
I get this every now and again with my Aeroforces Plugged in. The Scan Gauges actually shut down the Data Bus System. because the car thinks there is a problem with the Bus System. And having something plugged into the OBDII port can cause "interference" in that Serial circuit (there's a white splice connector behind the kick panel above the gas pedal which the OBDII port and all other module, including the DIC, use this to join all the separate "networks" together. It's basically just a LAN hub for the car).
as for the Voltage issues. Its a Common thing for the 04's
PostPosted: Wed Aug 19, 2015 5:56 pm
That's a relief to know that the scangauge caused that. Although I think there is a problem with the cable going to the fuse box. I had to jump the car today as it would try to crank but then click, and the car was missing hard while saying "CHARGING SYSTEM FAILURE" but if I messed with the cable it ran good again.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Aug 19, 2015 9:04 pm
Here is a video, once I got out of the driveway I floored it and that's all it would do. Once it gets moving it gets better but if I'm idling too long it starts doing it again. When it does it the volts jump between 13.5 and 11.2, when it dips that low it says charging system failure.
http://youtu.be/-bW59eYo1lw
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Fri Aug 21, 2015 6:47 pm
I pulled off the cable from the battery to the fuse box and it was rusted somehow. I replaced it and everything works right and now it says 14.5 volts while running.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Fri Aug 21, 2015 11:38 pm
Awesome! It was an easy fix luckily, just took some digging and agony. Funny how often those happen.
PostPosted: Sun Aug 23, 2015 10:40 am
LOTS of Mods
Good to Know Ryan, as I said it seems that a lot of 04's have this problem from what I have found
PostPosted: Sun Aug 23, 2015 4:28 pm
Well I went to go on a junkyard trip with Matt, and made it to the end of the street. It now shows - - instead of numbers for the volts on the DIC and it said service vehicle soon. So I parked it and took the 96. I'm going to hunt down every ground I can find clean and replace them as needed in a couple days.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Tue Aug 25, 2015 11:05 pm
It was the grounds, especially the one on the trans, as it was loose. I cleaned every one of them and I have driven about 60 miles and it all seems well. It's at about 14.8 volts as I still have the booster on the alternator.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Aug 26, 2015 9:54 am
Sweet! Fingers crossed that it is REALLY fixed.
There are no new unread posts for this topic. Voltage drop while braking issue 03 Bonneville
mikeman
Sat Aug 10, 2013 2:10 pm
Bugsi View the latest post
There are no new unread posts for this topic. No charge voltage, Low idle voltage, Check Charge System
03maroon
Sat Nov 19, 2011 4:08 pm
03maroon View the latest post
This topic is locked, you cannot edit posts or make further replies. 15+ Voltage!!
BFF_Larry
Sun May 22, 2011 11:01 am
willwren View the latest post
There are no new unread posts for this topic. Normal voltage
MStokes
Fri Nov 07, 2008 10:51 am
lunchboxx View the latest post
78elcaminoman
Tue Oct 28, 2008 9:27 pm
78elcaminoman View the latest post
