It is currently Thu Dec 13, 2018 9:12 am
PostPosted: Mon May 11, 2015 10:04 pm
Year and Trim: Pullied Clean 2k Black SSEi...
Hey all...last year I had the joy of needing to go under the driver seat, and replace my very corroded terminal block. I eliminated the water issues, and did an excellent job of properly soldering the connector, and shrink tubing it, etc. This week, the passenger door stopped working again, window, locks and mirrors, however now it carries new symptoms. The interior light won't turn off, the headlights are not turning on, and I have checked the splice, and it is dry and fully intact.
I tried the slam door technique with no luck, so has anyone other ideas to help?? Is there any other areas that could cause this interruption?
TIA...
PostPosted: Thu May 14, 2015 4:48 pm
*dang*...no ideas?? Is there any possibility this wire running under the pass seat could be subject to similar corrosions??
PostPosted: Fri May 15, 2015 12:49 pm
Most of those things are controlled by the passenger door module. Not sure on how it would affect the headlights, however.
PostPosted: Fri May 15, 2015 1:50 pm
Year and Trim: 2002 Bonneville SLE
Have any way of reading codes? Would point us in either. aground or general door module issue.
There are no new unread posts for this topic. 2002 bonneville a/c cold only on passenger side
labels99
Fri May 14, 2010 10:03 am
Archon View the latest post
There are no new unread posts for this topic. 2003 Electrical Issue
YBUY4DS
Fri Nov 30, 2012 12:19 am
There are no new unread posts for this topic. Electrical..or boost/vaccum issue?
DrivingExcitement
Mon Mar 25, 2013 8:31 pm
DrivingExcitement View the latest post
There are no new unread posts for this topic. Attachment(s) Need location of wire splice pack
JEFFSSSEI
Wed Nov 29, 2017 9:14 pm
JEFFSSSEI View the latest post
There are no new unread posts for this topic. 2000 Bonneville Electrical Issues
TD Waterhse
Tue Nov 16, 2010 1:24 pm
