It is currently Tue May 22, 2018 11:52 am
PostPosted: Tue Jan 13, 2015 8:00 pm
Year and Trim: Dark Green 1997 SSEi
Right now I cannot get any heat to blow out of the vents. When I try to switch the ECC to a different vent I hear a distinct click noise.
Could this be a blower motor problem or a relay?
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
PostPosted: Tue Jan 13, 2015 8:10 pm
Sounds like the little doors are switching positions, I assume that's what the click noise is. I would check the relay/blower motor.
"Penelope" - 2003 SLE - 172k Miles
2000 Honda S2000 - 52k miles
PostPosted: Wed Jan 14, 2015 3:24 pm
Testing the relay here in a sec.
Another question I had. What troubleshooting steps can I use to determine if the resistor or the actual blower motor is bad?
PostPosted: Wed Jan 14, 2015 4:19 pm
Sorry for the double post.
I went out to check the relays and fuses and for some weird reason the blower is working again... I didn't replace anything yet.
It started working again after I was adjusting the blower speed settings. When I moved it from 5 bars to 2 bars I could feel air coming out again. Moved it back up to 5 bars and it was blowing full speed heat and all.
Should I now be looking at a loose wire perhaps?
PostPosted: Wed Jan 14, 2015 6:42 pm
Did you touch anything yet?
I'm no expert on the 92-99, but on the 2000+ intermittent fan operation means the motor's brushes are worn, and replacement is necessary.
Another thing to consider, on the pre 2004 GPs, if the blower only works on full blast, that means relay.
Not sure how helpful or relevant any of that is, but just throwing out ideas.
PostPosted: Wed Jan 21, 2015 10:19 am
Year and Trim: 2003 SSEi
Unless the blower is not pushing enough volume (thus it feels like the vents aren't switching), it is not a player in switching where the air comes out. That would likely be a vacuum issue, and if it IS a vacuum problem, it’s likely you have collapsed nipples in the vacuum manifold on the HVAC controller. You might try searching on collapsed nipples and see what you can dig up, or go to http://www.trialsnuts.com/ecc.pdf - there’s some information and pictures in that article.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Fri Jan 23, 2015 8:44 am
Collapsed nipples? Sounds sexy :banana: LOL
That's a new one I didn't think of. Will check it out!
PostPosted: Mon Jan 26, 2015 3:06 am
Got her fixed! Turned out to be the blower motor. Tapped the motor with a wrench and it turned on. Bad bushing? Replaced her with a new one and everything has been working fine since. :banana:
There are no new unread posts for this topic. Interior Lighting Doesn't work
Yoshicoby
45
6407
Mon Sep 08, 2008 1:47 pm
Yoshicoby View the latest post
There are no new unread posts for this topic. drivers side door lock switch doesn't work!
vica
Mon Jan 26, 2015 2:43 pm
vica View the latest post
There are no new unread posts for this topic. Help! heat but blower wont work AND wipers wont come on
kaylasquires87
Sat Nov 27, 2010 12:22 am
Archon View the latest post
There are no new unread posts for this topic. Blower Motor doesn't always come on, please help.
BonniMan
Wed Dec 03, 2014 12:16 pm
BonniMan View the latest post
There are no new unread posts for this topic. a/c doesn't blow cold anymore, just kind of semi-cool/warm
powerdog
36
7529
Mon Jun 07, 2010 10:29 am
powerdog View the latest post
