It is currently Wed Jan 24, 2018 5:41 am
PostPosted: Sun Oct 26, 2014 6:14 pm
Year and Trim: 2003 sle with seei swap
2003 bonneville sle automatic heater control screen no power and lights same with heated seats please help getting cold out thanks for help :dontknow:
PostPosted: Mon Oct 27, 2014 1:26 am
Year and Trim: 2005 Bonneville SE 1SC L36 4T65E COTM 2/2015
Hi! Here is a link to the Owner's Manual in PDF form: http://www.vadengmpp.com/owners-manual/ ... eville.pdf
Page 43 of 63 is the beginning of fuse locations.
- BC
Brad - 1/21/1977 .. 10/23/2013 ...... Aaron - 1977 .. 2017 ..... ....... B & B
PostPosted: Mon Oct 27, 2014 8:07 am
Check if the fuses are all seated properly.
"Penelope" - 166k Miles
PostPosted: Mon Oct 27, 2014 5:01 pm
I checked every fuse and still nothing
PostPosted: Mon Oct 27, 2014 5:05 pm
Are there more fuses then under hood and back seat
PostPosted: Mon Oct 27, 2014 5:18 pm
If no lights at all on the switch its probably a bad seat module.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Mon Oct 27, 2014 6:58 pm
Would that affect the climate control?
PostPosted: Mon Oct 27, 2014 11:27 pm
Yes both seat and climate control are out at same time I have pics just don't know how to put them on climate control lights up red when I turn lights on but screen is black and blank
PostPosted: Mon Oct 27, 2014 11:29 pm
Sorry I missed the part about the climate control also being bad. It sounds like two unrelated problems as their wiring comes from two different areas. I'd start by removing the climate control and see if the wiring is damaged.
-Andrew-
PostPosted: Tue Oct 28, 2014 9:09 am
The only two fuse boxes are under the hood and the rear seat cushion. You could try and switch some fuses around. I had a similar issue and had to bend the prongs of the fuse to make it contact better. However, my radio also didn't work along with the CC and seats.
PostPosted: Tue Oct 28, 2014 12:31 pm
I checked wires look fine do u have a diagram of what wire is power and I can try to run a power wire and see if that works thanks for the help
PostPosted: Tue Oct 28, 2014 12:32 pm
For the dual climate control
PostPosted: Tue Oct 28, 2014 12:45 pm
I put a test light on plug and only time i get power to that plug is when i turn lights on and the climate control would light up red when i turn lights on just no power to unit and screen itself
PostPosted: Thu Oct 30, 2014 1:01 am
2004 Bonneville GXP
The Climate Control Module is controlled by the data link to the Instrument panel module. The heated seats have modules under them and are controlled by data links to the rear integration module. Hard to day what the problem is. You should check all your grounds in the passenger compartment, under the seats, front and back and in the front cowls behind the trim panel. If no luck there, then you may have to start swapping out the climate control, IPM, RIM or heated seat modules with good ones. Or find someone with a Tech II scanner to run the diagnostics.
bobgto65
There are no new unread posts for this topic. Heated seats?
irish91983
Thu Aug 20, 2009 11:07 am
irish91983 View the latest post
There are no new unread posts for this topic. add heated seats
pmicaza
Sat Jan 23, 2010 1:34 pm
redzmonte
Fri Apr 19, 2013 7:40 am
There are no new unread posts for this topic. Heated Seats, second attempt?
logandbz
Mon Nov 14, 2011 11:21 am
DCJREDLINE View the latest post
There are no new unread posts for this topic. Heated seats 2000 ssei
Rubidon
Thu Dec 26, 2013 10:42 am
cron
