It is currently Wed Oct 08, 2025 6:48 am
 Post subject: Distributor question
PostPosted: Wed Feb 20, 2013 1:38 pm
Year and Trim: 1993 ssei supercharged bright white
Hey guys, I just changed my plugs with high performance plugs and the wires with high performance msd wires, and I just found out the distributors are origonal, they have 180k miles on them and so now I want high performance distributors to complete the set, but I am doing so research and I can only seem to find the stalk distributors, would they even work in my car (1993 pontiac bonneville ssei) bc right now I have the 3 seperate distributors. Are there high performance distributors that are the 3 seperate ones or do I have to get the stalk one (where all the wire terminals are on one cap) and if I do need the stalk one will it even be compatable with my car, and the big question is will the stalk one even fit under the hood, aka will I be able to close the hood.
Thanks and cheers guys
1993 SSEI SUPERCHARGED AKA "ANGLE"
180,000 MILES
2000 WATT SYSTEM, ALPINE 7 INCH FLIP OUT TOUCH SCREEN TV, 2 12" SUB WOOFERS IN THE TRUNK
2000 WATT ALPINE AMP
LADIES CALL IT A ROLLING CLUB, I GUESS THE VIBRATIONS GET THEM READY FOR SOME FUN
SSEI= SSEXI
NOW WITH BEAUTIFUL BLUE NEON UNDERGLOW
CERTIFIED EAGLE SCOUT MAY 19 2009
REFERRED TO BY EVERYONE AS JAMES BONDS WEEKEND CAR, REFERRED TO BY ME AS ANGEL
 Post subject: Re: Distributor question
PostPosted: Wed Feb 20, 2013 2:16 pm
Can anyone vouch for Jacobs? They seem to be the best so far that I have been able to find
180,000 MILES
SSEI= SSEXI
PostPosted: Wed Feb 20, 2013 2:19 pm
There isn't a distributor, in the traditional sense. We have coil packs. Three seperate ones with 2 posts on each. OEM replacements for a 96+ L67 or MSD brand are what I would suggest.
PostPosted: Wed Feb 20, 2013 2:21 pm
They're coils, not distributors, first off, like John said. If you feel the need to upgrade, go to the junkyard and find a Series II supercharged car, and get them off of that. There is NO need to spend $50 apiece on the MSD coils. They were actually designed for the L36, and have a bad track-record. You also blew about $50 buying their wires too.
What kind of "High Performance" plugs did you get suckered into buying?
PostPosted: Wed Feb 20, 2013 2:46 pm
I've been happy with my MSD coils. Testing suggests they are pretty close to Series II L67 coils, plus, they're red.
PostPosted: Wed Feb 20, 2013 2:50 pm
Year and Trim: '02 SSEi
J Wikoff wrote:
plus, they're red.
Seems legit.
PostPosted: Fri Feb 22, 2013 12:52 pm
to 00Beast, the plugs i got were ac delco double platinum rapid fire.
so everyone seems to be vouching for msd? because i have read a lot of different personal reviews and it seems that people dont like msd coils, they say their engine runs rougher at idle and foul up relatively quick. and ive read reviews about jacobs coils and so far have not seen any negative reviews, thats why im leaning heavily towards jacobs
and to 00beast, why do you say i blew 50$ on their wires? why was that a bad idea to get the msd wires? (not being sarcastic, i know just about nothing about wires and i would seriously like to know why it was a bad idea so i can increase my knowledge a bit more)
180,000 MILES
SSEI= SSEXI
PostPosted: Fri Feb 22, 2013 1:03 pm
Got your PM, just gonna comment here.
Take those plugs out NOW. Platinum plugs turn into a glow plug in supercharged engines, and you will cause misfires at best, and blow a hole in a piston at worse. Copper or Iridium only in S/C engines. No exceptions, and I don't care what the guy at the dealer, parts counter or your buddy told you. They are going to do damage.
There is no need to get aftermarket coils. If you feel you absolutely need a coil upgrade, get a set of Series 2/3 supercharged coils. They're the "best" factory coil. The stock coils work just fine, hell, most of the fastest guys still run stock coils.
A wire is a wire after a certain point. You're not running a high-performance race engine. Most of the top 25 3800's use NAPA Beldin wires. If you feel like the look was worth it to you, then I guess there are worse ways you can spend $50.
PostPosted: Fri Feb 22, 2013 1:46 pm
Holy crap seriously? The platinum plugs will do damage? If so right after I get outa class today I'm going right over to advanced auto parts and getting ac delco iridium plugs immediately, thank you very much for your information and helping me avoid serious engine problems, I've only run the for about 4 days and put 40 or so miles on them, do you think damage has been done or did I catch it, or rather you catch it in time?
180,000 MILES
SSEI= SSEXI
PostPosted: Fri Feb 22, 2013 1:49 pm
Unless it was 40 miles at full throttle, I don't think so. It happens at wide-open-throttle under boost, they heat up and cause big knock.
PostPosted: Fri Feb 22, 2013 2:11 pm
Ok perfect, I hit the supercharger once in a blue moon so I think I'll be alright
180,000 MILES
SSEI= SSEXI
PostPosted: Mon Feb 25, 2013 9:23 pm
You should still get them out of there.
PostPosted: Fri Mar 01, 2013 12:55 pm
plugs are out and changed with denso iridium plugs, thank you again 00beast for the very very useful information
180,000 MILES
SSEI= SSEXI
This topic is locked, you cannot edit posts or make further replies. DISTRIBUTOR HELP!!!!
Batmobile66
Mon Mar 22, 2010 4:52 pm
There are no new unread posts for this topic. HUD Question
SteveND
Sun Nov 11, 2012 10:24 am
sethjamesrimrodt View the latest post
There are no new unread posts for this topic. AL7 Question...
ChilinMichael
Tue Nov 24, 2009 6:07 pm
There are no new unread posts for this topic. Battery Question
jorni
11
2993
Sat Mar 02, 2013 9:06 am
Jrs3800 View the latest post
There are no new unread posts for this topic. headlamp question
SLE_CHAMP
Sun Jun 07, 2015 9:51 pm
ddalder View the latest post
