It is currently Tue Jun 02, 2020 4:19 pm
PostPosted: Sun Feb 20, 2011 3:22 pm
Year and Trim: Pontiac Bonneville 1995
There is such problem! I include yard keepers and they start to submit life signs only on the maximum speed and that rise only on 10 % and then again fall and so work constantly! When went from Moscow having passed 700 kilometers they like отмерзли and even have few times worked then with it is new have started to rise not above 10 %. What thoughts are? The frost stands up for last week 25С. Can it is simple that that has frozen?
Has removed today a plastic cover having unscrewed 3 bolts but there all works as all is necessary also in greasing even signs of oxidation or a moisture isn't present.
PostPosted: Sun Feb 20, 2011 3:58 pm
I'm having trouble understanding. Is this an engine problem, or the radio, or the heater...?
PostPosted: Sun Feb 20, 2011 4:01 pm
I understand you're translating from Russian to English, but could you please be a little more clear in your posts? That would help everyone.
PostPosted: Sun Feb 20, 2011 4:15 pm
The matter is that:
Having turned the handle of a screen wiper (yard keepers) Yard keepers 10-15 centimeters join but rise only and at once come back in a bottom. In other words yard keepers clear only 10-15 centimeters has flown down from below and above don't rise though don't stop and continue to move. I hope so it will be more clear. Tomorrow I want to go on a hot sink and to wash out all lattice which under yard keepers be hot water with calculation that all that there could to accumulate and freeze will get warm.
PostPosted: Sun Feb 20, 2011 4:22 pm
Oh, the windshield wipers? They only go up a little ways and go back?
PostPosted: Sun Feb 20, 2011 4:25 pm
I think I've seen this problem when the wiper arms were coming disconnected from the linkage.
yes :beerchug:
PostPosted: Sun Feb 20, 2011 4:32 pm
It is necessary to remove the engine of the wiper?
PostPosted: Sun Feb 20, 2011 4:40 pm
Where it is possible to download the instruction on Pontiac Bonneville
PostPosted: Sun Feb 20, 2011 5:27 pm
This thread might help.
viewtopic.php?f=19&t=1370&hilit=wipers
PostPosted: Sun Feb 20, 2011 6:42 pm
This theme not the such! In it it is told that one of yard keepers doesn't fall up to the end and at me they rise into place but don't rise above than is shown on a photo. We will admit that has flown down it of 100 % and lifting of the yard keeper only on 10 % and at once return to a starting position.
I the bad artist)))
In the first drawing normal work of yard keepers! Full scope.
In the second drawing my situation. Not full scope.Image
PostPosted: Sun Feb 20, 2011 9:54 pm
Year and Trim: 96 SE
there is no such problem covered in the factory service manual. best i can understand, you are saying the wiper blades only rise to about 10 per cent 0f normal operation. so it would appear that you have obstruction, such as ice. or the wiper motor gearing is stripped. since both wiper blades move the same distance (per your drawing) i would suspect that the wiper motor (engine) may have to be replaced.
PostPosted: Mon Feb 21, 2011 3:08 pm
Year and Trim: 1998 Bonneville SSE
I had one that would do this but it would wait a half a second before moving then would go up just a bit and then stop and go back down. The problem is the windshield wiper froze to the window and the motor turned the bolt, so re-tightening both and retrying might help.
98 Bonneville SSE
03 GrandPrix GT
CAI, U-bend delete, Ported L67 TB, L26 PLIM and UIM.
There are no new unread posts for this topic. No start due to electrical problem and/or security problem
SPLLOUDER
Wed Oct 17, 2012 8:53 am
sethjamesrimrodt View the latest post
There are no new unread posts for this topic. upgrade alternator on 1995 sse
loud95sse
Fri Jul 25, 2008 2:00 pm
Maymybonneliveforevr View the latest post
There are no new unread posts for this topic. 1995 SSEI Alternator
tripscarcare95
Mon Jul 11, 2011 4:29 pm
tripscarcare95 View the latest post
There are no new unread posts for this topic. 1995 SSE HUD not adjusting properly
SSP_SSE
Tue Nov 25, 2008 2:52 pm
jabu View the latest post
There are no new unread posts for this topic. 1995 ssei alternator size?
lfreng
Wed Aug 12, 2009 12:23 pm
