It is currently Mon Feb 18, 2019 9:01 pm
PostPosted: Sat Jan 15, 2011 3:54 pm
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Does anyone know if I can replace the turn signal(wiper switch mainly) stalk without removing the steering wheel?
If not am I better off just getting a whole replacement steering column from a salvage yard?
Problem I'm having is that to turn the wipers on you twist the 'dial' on the end of the turn signal stalk, but now the wiper 'dial' just spins and the wipers don't come on.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
PostPosted: Sat Jan 15, 2011 4:14 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
just yank it out, I have one if you need it.
PostPosted: Mon Jan 17, 2011 5:34 pm
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Switch assembly or column?
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
PostPosted: Mon Jan 17, 2011 5:39 pm
do you need this? or is the problem in the column?
this just pulls out and remember to disconnect the wire connector.
PostPosted: Mon Jan 17, 2011 6:23 pm
01 SLE
02 GTP40th
02 SSEi
06 GP GT
I just wet my pants -I thought there was a LOT more to it than that!!!
I'll take it I'll take it!!
I'll let you know when I get an aluminum oil pan pulled so we can get the exchange taken care of. Should be about a week or two max (I'm hoping -have only done 3 motors since Nov 1st), but if you want me to just pay now w/paypal I can do that too.
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
PostPosted: Wed Jan 19, 2011 6:36 pm
*dang*, Marty. Show a little gratitude next time!
(and go change your pants)
PostPosted: Wed Mar 11, 2015 9:46 am
Year and Trim: 1996 SE & 1999 SLE
My daughters dog chewed off the end of multifunction switch so I can't use cruise control on my 99SLE. I have a 96 SE for parts. How do I take switch out? Do I have to remove steering wheel??
There are no new unread posts for this topic. Turn signal gremlins (02 SSEi)
1994se
Sat Apr 30, 2011 2:53 am
There are no new unread posts for this topic. Where Is The Turn Signal Flasher At?
Blown93SSEi
Thu Sep 20, 2012 12:58 pm
Mad Myche View the latest post
There are no new unread posts for this topic. Turn signal problem
theax40
Tue Jun 19, 2012 8:51 pm
theax40 View the latest post
There are no new unread posts for this topic. Right front parking/turn signal.
gold_xero
Fri Aug 03, 2012 10:43 am
gold_xero View the latest post
There are no new unread posts for this topic. Turn signal repair. NOW WITH PICS! Please help!!
labonnevillastrangiato
Mon Sep 08, 2008 2:12 pm
Alibi View the latest post
