It is currently Mon Feb 18, 2019 2:51 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Um, my DIC won't reset
PostPosted: Tue Jun 08, 2010 9:28 pm
Yeah, so I'm trying to reset my Fuel Used and Average Fuel Economy on my DIC and holding the reset button in doesn't seem to be doing it anymore. Everything seems to work except resetting it. I had a little problem the last time I tried resetting it but it eventually reset after a combination of button presses and holds. Any ideas? Is this just a board behind the buttons or is this a bigger computer issue? :roll:
2005 Bonneville GXP (SOLD), Crimson Red Tintcoat
Other Rides: 2009 Solstice GXP Coupe #606, Cool (Liquid Silver) | 2007 BMW 750Li, Toledo Blue Metallic
Past Rides: 2007 Grand Prix GXP, Red Jewel Tintcoat | 2004 Grand Prix GT2, Fusion Orange | 2002 Bonneville SSEi, Black | 1999 Regal GS, Black | 1997 Bonneville SSE, Blue-Green
1994 Cutlass Supreme S, Turquoise | 1989 Cutlass Supreme IS, Bright Red | 1988 GMC Sierra 1500, Dark Red | 1982 Regal Sport Coupe, Maroon/Silver | 1975 LeSabre, Beige
Wife's Chariot: 2006 Buick Rainier CXL, Red Jewel Tintcoat
PostPosted: Tue Jun 08, 2010 10:01 pm
How long are you holding it? Hold it longer.
-Andrew-
PostPosted: Wed Jun 09, 2010 12:47 pm
I've held it for over a minute and it didn't reset.
PostPosted: Wed Jun 09, 2010 12:51 pm
If your DIC fails to reset after four or more hours, you should consult a professional.
PostPosted: Wed Jun 09, 2010 12:55 pm
I guess I knew I was setting myself up for that. :laughing3:
PostPosted: Thu Jun 10, 2010 8:38 pm
Bump! Any ideas?
PostPosted: Thu Jun 10, 2010 9:51 pm
About the only thing I can suggest is to remove the instrument panel, take that module out and apart, and see if you see a problem with the buttons.
PostPosted: Sat Jun 12, 2010 10:46 am
That's easy enough. My dash has been partially apart for over a month. The DIC module is just sitting in the hole where its connection point is. I'll try unplugging it and plugging it back in to see if that makes a difference, but I doubt it will, as I've had the battery disconnected a couple times recently. I'll try it anyway, and if that doesn't do anything I'll dig deeper into the module.
PostPosted: Mon Jun 14, 2010 8:26 pm
Ok, I discovered more tonight. It appears for every power cycle I can use the reset button once, i.e. if I turn the key to on, I can reset one setting, like the fuel used. If I select my way through to avg mpg during the same cycle, I can't reset it, but if I turn the key off and then on again, I can reset the avg mpg. Just plain weird.
PostPosted: Sun Jul 11, 2010 12:06 pm
Finally got around to doing that and cleaned all the contacts and it seems to have done the trick.
PostPosted: Sun Jul 11, 2010 12:23 pm
Good job!
PostPosted: Tue Aug 17, 2010 10:32 pm
Looks like the problem is back. Avg. MPG is hovering around the 19.x range within a couple tenths and I can't reset it. Even if I sit at idle with the engine running for 10+ minutes it stays around 19.3. I have been able to reset Fuel Used reliably, just not Avg. MPG. Does anyone know if this computer is self-contained in the button module or the gauge cluster or some other place?
PostPosted: Tue Aug 17, 2010 11:21 pm
Year and Trim: White 2000 Bonneville SLE
It is definitely not in the buttons.
You could try disconnecting the battery for 30 minutes to do a hard reset.
Russell (Rus or Rusty)
White 2000 SLE - 161k Miles
Current Mods - Transgo Shift Kit, 180* Drilled Thermostat, NGK TR55 & Belden Plug Wires, Suspension Energy Endlink Upgrade, "Stock" 12-Way Power Seats, "Stock" Heated Seats, "Stock" Homelink GDO, Cleared Corners, Pins & Dealer Badge Removed, 2002 56I Center Console, Dash Trim, Steering Wheel and Shifter Swap, Auto-Dimming RV Mirror, Pioneer AVH-P4000DVD MP3/USB Headunit w/ Steering Wheel Controls and iPhone Music Interface, Hood Protector, Gutted Airbox w/ K&N Filter.
Mods in Progress - SSEi Inflator with Stock controls, Chrome "Swoopies" (Have rims, need tires)
Future Mods - Viper 5701 Remote Start with Smart Start and 35% Window Tinting
PostPosted: Wed Aug 18, 2010 10:02 pm
Just had the battery disconnected a couple weeks ago when I was putting the dash back together. Guess I have to take it apart again. :sad5:
PostPosted: Fri Aug 20, 2010 9:10 am
IIRC, those switches have a small metal dome covered by clear tape that when depressed, makes contact with pads on the circuit board. Did you remove the tape and the domes to clean underneath?
PostPosted: Sun Aug 29, 2010 12:47 pm
I've had a similar problem with my GXP for years. I recently pulled out the switch panel and tested it with a voltmeter. I found that if I push on the left side of the botton, it works about 90% of the time. If I push on the right side of middle of the button, it usually doesn't work. I also found that after the initial push of the button, if no connection is made, no amount of pressure or side to side movement on the botton will complete the circuit.
I will probably either get a switch or try to clean or repair mine, but for now pushing on the left side of the reset button seems to work fine. I would get a kick out of hearing that this works for you too, so try it and let us know. :)
2005 GXP Silver, Gutted Airbox, K&N filter, 14.61 @ 94.31 mph.
1987 t-bird 2.3 turbo, stock motor with home-ported head, big turbo, big exhaust, alky injection, a bunch of other little stuff, 13.65 @ 102 on radials.
PostPosted: Mon Aug 30, 2010 9:47 pm
Thanks for the suggestion, but, nope. Pushing any part of the switch has the same result - nothing. When I get a chance, I'll take it apart again and see if I can figure out what is/isn't making contact. Off comes the bezel again. :roll:
PostPosted: Wed Aug 24, 2011 11:24 pm
Did you ever figure this problem out. my car is doing the same thing. it is a 2005 GXP!
thanks
PostPosted: Fri Aug 26, 2011 7:54 pm
Nope. I've taken the button panel apart and cleaned the little carbon contacts and circuit board several times, not that they ever appear dirty. Each time I do that it works for a short time and then starts doing it again. I'm not sure if cleaning the contacts is allowing it to reset, or if unplugging the button panel to do that is clearing something in the cluster (DIC) which then allows me to reset it a few times but which ever it is, it isn't permanent. :dontknow:
PostPosted: Sun Feb 08, 2015 7:08 pm
Year and Trim: 2003 SSEi
I just ran into this today. Reset the mpg once and now it won't again...
Doesn't look like there was a definitive solution found over the last 4yrs huh?
2003 SSEi - 240hp of stock supercharged, grocery getting, kid carting, weekend vacationing, daily driving light bronze mist excitement.
There are no new unread posts for this topic. How do I RESET the Car to communicate with the rebuilt motor
phyllismarie63
Sun Nov 01, 2015 11:35 pm
There are no new unread posts for this topic. gages, compass, DIC reset when driving
SSP_SSE
Sat Aug 30, 2008 2:56 am
SSP_SSE View the latest post
There are no new unread posts for this topic. Select Button, Trip Reset Button etc.
ART
Tue Jul 27, 2010 5:06 pm
ART View the latest post
